| 6 cyl Bristol cars Type 400 to 406 - restoration, repair, maintenance etc |
There is no need to improve the braking on a 406. The Dunlop set up is
superb and out brakes many a modern car. My 407 somewhat surprises the MOT tester every year. The brakes are the same as an E type and many of its contemporys. They were only stopped from making them, as the designers had left their previous employment and set up with Dunlop to make an improved version. Dunlop were taken to court and ended production after losing the case. Past Parts of Bury St Edmunds are experts on the brakes and have everything in stock for you, they re-sleeve the brake cylinders with stainless steel. I have tried different pads and put in "Green Stuff Pads" but a couple of laps of Le Man glazed them up and produced an awful squeal. I have gone back to the old style (with out asbestos) and we are now back to normal. Past Parts are to be found on 01284 750729 www.pastparts.com restore@pastparts.com Fax 01284 756240 Unit 4 Chase Road, Northern way Industrial Estate Bury St Edmunds Suffolk IP32 6NT If it aint broke dont fix it, restore it! Nick. |
Nick, you may believe that, but I doubt very much that anyone else does.
Kevin,
It was rated the best of brakes in its day and without reverting to modern brakes and ABS there is no better brake. Maintenance is the answer, good discs and good pads. I doubt in their time Bristol would not have fitted them if they were not the best available. Nick. |
Nick, "in it's day" are the important words here, and it's day was around the late 1950's and early 1960's, before Girling made it's calipers that were twice the size, which Bristol and many other performance car manufacturers adopted.
I agree that they will work better when everything is set up as per manufacturers spec, as most mechanical things will, but in reality brakes also have to work well in sub-optimal condition. My experience with the Dunlop brakes were on an Aston DB4. I had the brakes rebuilt after I bought the car so they were in perfect condition. They were adequate around town, but when I used the car in a rally (Classic Adelaide) they suffered badly from brake fade. This is a widely reported problem with the Dunlop brakes which is no doubt why so many companies have developed replacement upgrades for them. Incidentally, Bristol now offer brake "upgrades", so obviously they too believe there is room for improvement ![]() |
Most classic car owners don't race their cars and in normal road conditions Dunlop brakes are adequate, however people expect and are used to more.
Everyone I know that have uprated the standard Bristol brakes to Coopercraft seem delighted. I was happy with the Dunlop's on the 408 and they seemed on a par with the 411 brakes until a bit of brake fade kicked in. |
"it's" ? Not even in Australia for the possessive. "its" in English, around the world.
Don't be oversensitive to this...it's a very common error. |
And this has what to do with cars ? or am I being over sensitive ? ( note two separate words ) |
Where do you want to draw the line with grammar, spelling, punctuation, and sentence construction if you don't want to follow the rules? Last edited by browning l; 03-09-10 at 07:05 PM. |
Cass xxxx |
Don't be over sensitive and if you feel overcome may I suggest putting your head between your knees and taking a deep breath. It may be beneficial to do this in one of your five Bristols - may I suggest you position both kneees and face immediately adjacent to the front footwell air vent after first adjusting the temperature and fan controls to a suitable temperature and air velocity. If you are as sensitive as me you might like to apply some Clarins facial moisturiser to avoid windburn which gan give your lips a dreadful chapping. Changing the subject somewhat, are you going to Rufforth tomorrow? I may go but my Willie wants to stay at home in bed. Prolly with an english language excercise book doing double declentions of his third ablative. I may see you walking around, clutching my beaver brown Osprey manbag and casting an appraising eye over the stalls with the greasy bike bits and attending rough leather clad biker types. Take care, Cass xx |
Cass,
Thought you might be jumping into the fray when Colonel Sanders began his grammer (sic) lesson... been a while, great stuff as always. Gotta git on my horsey and run, the revenooers are a-comin'! Cheers, HouTex |
