Urgent Help
Old 29-04-26, 08:49 AM
Default Urgent Help
My Bristol 411 has decided to not start 3 days before the BRDC Meet at Silverstone.
When I turn the ignition key I just get a clicking noise and start not engaging.
I am assuming the starter motor has given up the ghost....
Unless anyone has any other ideas ???????
Assuming this is the problem
What is the part number for a Bristol 411 Mark 1 starter motor?
What was it from??
many thanks for any help
Martin
Old 29-04-26, 09:05 AM
What was it from??
Martin
Have you checked the battery?
Forgive me if it sounds obvious, but even a relatively new battery that is in less than tip top shape can cause issues.
Old 29-04-26, 09:17 AM
First thing I tried.
Put a jump pack on but same problem just a click.
Ran gear lever up and down, even tried starting in Neutral
Has done this a couple of times in the past but would start after a few attempts
Old 29-04-26, 09:32 AM
Real Steel will almost certainly have a starter motor in stock and they normally deliver very quickly.
https://www.realsteel.co.uk/
Old 29-04-26, 09:33 AM
Bad contacts (oxydized) on the starter motor or the safety battery connector/trickle charger? It happened to me
Best
Stefano
Old 29-04-26, 12:50 PM
Use voltmeter to confirm voltage at battery and ensure connections at starter are tight. Also a few taps on the starter with a hammer can free it up if stuck.
If battery is older, the cranking amps may not be what they should.
Good luck and let us know the culprit once sorted.
Paul
Old 29-04-26, 01:49 PM
Paul
Thank you everyone.
have gone for the warts and all approach.
Ordered Starter, Inhibitor, Solenoid and battery and will have the lot replaced tomorrow. Not taking any chances for Saturday
Old 30-04-26, 06:40 AM
Martin,
Have you checked the starter relay and its connections, earth wire on the side of the transmission and your earth wire connection on the side of the engine is clean and tight?
Brian
