Water Pump
Old 08-12-25, 03:35 PM
mgdmurray mgdmurray is offline
Default Water Pump
Does any Bristol enthusiast have an spare water pump available for a Bristol 406, 100 engine? Any condition is acceptable. Thanks Mike
Old 08-12-25, 09:21 PM
I have two rebuilt water pumps suitable for all 6 cylinder Bristol engines, send me a message if you want more details . Postage from Australia can be expensive but will get you a quote.
Old 08-12-25, 09:28 PM
I think at least the body is the same on any water pump from 401 to 406 with built in thermostat.
New units are available from a number of sources including Ebay.
If you have an old unit that leaks or has a failed bearing it may be possible to get it rebuilt for quite a reasonable cost. I have just had a new bearing and seal fitted for about £120.
Old 12-12-25, 09:11 AM
Default Water Pump
Hi David C
Thanks for your note on re-furbing a water pump. I just need to find a unit and see how it performs, etc. Thanks again.
