Wanted V8 air cleaner drum
Old 11-07-24, 06:04 AM
Peter Hoskin Peter Hoskin is offline
Default Wanted V8 air cleaner drum
Air cleaner cylindrical air filter case for Bristol 603 or similar. pjhoskin@optusnet.com.au
Old 11-07-24, 10:03 PM
Sam410 Sam410 is offline
I have one from a 411 s2 available but I do not know if it is the same as a 603's. (It is different from a 410's.) I can send a picture tomorrow.
Old 11-07-24, 10:43 PM
Default Air cleaner drum for a 603
Thanks, a picture would be appreciated. I am not sure of the differences.
Old 18-07-24, 03:06 PM
Sorry for the delay getting back to you.
It is 45cm across the base, with a 32.5cm diameter air filter inside (which needs replacing!).
Old 24-07-24, 10:49 PM
Thanks Sam, the critical measurement is where it seals with the carb. top. I have changed to a Rochester carb. which may have a different dimension which is 130mm. ie the inner diameter of the hole in the bottom.
