AC Ace info sought
Hi
Just wondering if anyone knows the fate or whereabouts of AC Ace original Reg No 102EPK first registered late '57 or early '58 in Surrey. |
AC Ace 102 EPK
Hi.
According to the AC OC register of cars, the chassis number of this car is AE 413, last known owner J Davison in Hampshire. No date given for this last bit of information. I suggest you write to the AC Ace registrar (don't know the name of the current one, but you can find such info from their web-site) and see what they will tell you. Andrew Blow |
Hi
Thanks Andrew, will pass this on to the person who was asking me if I could find it using the BOC register. |
AC Ace info sought
The following is information from the book
"Ace Bristol Racing" by John McLellan & Tony Bancroft. Printed in 1998 Chassis AE413 , Engine CL-2314, Ex Works 1/2/58 ,Regn 102EPK, Location UK , Last Owner L Davidson I suggest you contact the ACOC Ace Registrar and he should be able to give you the current owner Geoff Dowdle |
Hi. New to this forum, but I`m a long standing ACOC forum member.
This Ace is unlikely to show up on the BOC register as it didn`t have the Bristol engine, the 'AE' chassis number denoting use of the AC straight six(unless, of course, it later acquired a Bristol unit). Bristol-engined Ace chassis numbers are prefixed 'BE'. Both AE & BE gain an 'X' to indicate export (LHD). Regards, Nik. |
| All times are GMT. The time now is 12:28 PM. |
