-   -   Bristol 603 - compartment drainage (https://www.bristolcars.info/forums/showthread.php?t=2412)
Peter Hoskin 11-08-25 07:34 AM
A recent 2 hour trip in heavy rain resulted in a wet carpet in the boot, mainly on the near side. It would appear the water was coming down rather than up. Removal of the carpets etc. should 2 pipes clipped to the wing which exit behind the rear wheel with one only on the offside. I assumed one came from the petrol filler compartment and the other from the cabin air exhaust space. Previously I had noticed drainage from the petrol filler comp. dripping from under the rear wing but on this occasion I find the drain to be blocked so I need to explore further. Removal of the grill of the cabin air exhaust space revealed no drain from that space, surprising because a car wash or enthusiastic use of a hose must lead to water entering this space.
So what is the purpose of the second drain pipe? I thought it might be an air release from the top of the fuel tank but there is no such fitting so what is the purpose of these drain pipes, one each side of the rear wheel? A search wire went a long way up it.
Geoff Kingston 11-08-25 11:07 AM
On my 603 the vent for the tank comes into the boot on the passengers side and exits through the boot floor. From memory the second pipe on that side is a drain to the filler compartment but I will check the car later. Also to see if there is a pipe on the drivers side. You can see the tank vent pipe in the photo of your petrol tank.
Update,
Having looked at the two 603's on WLO the only pipe going through the boot is the vent for the tank. On 4981 H the trim is back in place and with a bad back I cant for the time being remove it but last winter when we did some minor boot floor repairs we encountered two pipes the larger being the tank vent, the smaller rubber pipe was a drain for the petrol filler compartment, as the drain hole in that area is in the front corner I would have expected the drain pipe to run down the front of the wheel arch but on 4981H it went through the boot. Indeed I think we had to replace a section of it as the rubber had gone hard and split. Sorry I can't be more help.
Peter Hoskin 11-08-25 11:05 PM
Bristol 603 Electrical Circuits
Thank you Geof,
The picture of the tank was a couple of year ago when I was tackling something else so was not looking for air vents. It is not exposed at the moment. However the yellow 'pipe' on the top nearside appears to have an electrical lead? and there is no equivalent from the offside? I inserted a wire into the exit point and it went a long way and could easily have reached the top of the tank.
On the water leakage question I dont appear to have found the source but have applied sealant to the join between the fibreglass air vent exit and the car body and will test it before replacing carpets. (why did I not test it before applying sealant?)
Geoff Kingston 12-08-25 11:03 AM
Peter, I have not got the wing vents on my cars as they are both earlier models, we did notice seam sealer had been applied on some areas of the boot floor we repaired, on WLO I will have to get the rear seat out at some time as their is a slight smell of petrol especially after filling up so I need to check the condition of the vent and filler pipes. Hope your sealer on the vent has done the job.
