406 wheels / hubcaps
help needed
I am restoring a 406 which came with 5 wheels which had little rubber buffers in the three holes which I assumed were used to. rest the hubcap on I was told that there are two types of cap arrangement, I got some hub caps which I was assured were for a 406 they only have two little holes in them which I assume take the round Bristol disc having just got round to looking at fitting the caps it's clear they will not fit the wheels as there aren't ant round spigots for the cap to clip over so the help I need is pictures and dimensions of the screw type cap fitting or details of how the clip type works any one help I'm not far from Warwick |
The 406 had an insert called a spider that went in the middle of the wheel. The chrome dished hubcap was held by a large knurled edged piece that carried the Bristol badge. This screwed into the spider. There was a polythene washer between the hub cap and the badge carrier. The wheels also had chrome embellishment rings.
406 hubcaps
406 hubcaps have a central Medallion which rotates, Undoing a screw which locates into an aluminium detail in the wheel centre.
So the hubcap is screwed down onto the rubber buffers. The earlier 2 L ones all have a pop on hubcap which just springs over three nipples. These are threaded into the three holes you have seen with the rubber buffers in. I fitted 406 wheels to my 400 (They are 4 1/2 J, slightly wider and suit my Dunlop radials fine.)and simply threaded the three holes, had some nipples turned up on the lathe and screwed them in. Result. Sounds like you need the 406 type hubcap and the central aluminium boss which they thread into. If you see what I mean! |
Mike406,
see attached page from the 406 Spare Handbook which clearly shows what was originally fitted. It sounds like the hubcaps you bought are not for a 406 and you need items #4,5,6,7,8,9& 10 I hope this helps Geoff |
hi David
do you have any pictures and any dimensions so that I can arrange to fabricate a replacement set thanks Mike |
I have a bent original hub disc and a good badge surround that I would be willing to part with. Just need to find them... May also be able to help out with badges.
all
thanks for the info I'll look to see which route to take clearly if any one has a spare spider arrangement I could borrow then that's the ideal cheers Mike |
I seem to remember the Volvo 144 had a similar arrangement. May be worth investigating dimensions of the spider they used
http://www.bristolcars.info/forums/a...1&d=1631699611
Found them! Not quite concours but may be recoverable. Certainly a good pattern |
406 hubcaps
Hope this helps!Attachment 1538
does anyone have the dimensions of the round "bollard" which holds the clip-on style hub caps as it seems I have bolt-on style wheels and clip-om style caps and badges
Did you sort this, Mike? I just found a second badge surround for 406 hub cap.
yes I had some "pegs" made to fit a clip-on hub cap |
| All times are GMT. The time now is 11:18 AM. |
