Restoring Arnolt Bristol # 3075 need help
Hello everyone !
I am currently managing the complete restoration of a 1954 Arnolt Bristol, chassis # 3075. I have a few questions regarding this car, as it was heavily damaged at some point in it's past life. The car is currently completely disassembled, media blasted and coated in epoxy primer. It's about to undergo major sheet metal fabrication and replacement. In my research, I've noticed a few different grille shapes and nose opening shapes, and I'm uncertain on what this car is actually supposed to look like. Were all '54 cars identical in the nose and grille, or was there a difference between the various models? I believe this particular model is a D, = Deluxe. Can anyone identify for certain what the grille and nose opening should look like on this particular car? Also, is there a color code available for the "Post Office Red" on the exterior, and the grey color on the engine compartment? I'll have many questions regarding this car during it's restoration process, and hoping to find help with locating parts as well. Thank you everyone! |
Arnolt Grill
Hi Restoguy - You may like to press on my username (UK6) above and if you email me I can send you some info inc photos.
B |
If it's too much trouble, feel free to send the photos to me I will post them for you. Kevin |
Thanks Kevin,
Here is the link to the shops website, it may be easier for viewing photos as we keep the site updated often. Any information regarding parts will be welcome! UK6, wonderful information, thank you so much! Hoping to find a car here in person that we can go look at, perhaps make templates etc.... Classic Restoration Home Scott |
3075 resto
Glad you found your way to the site. You will certainly get all of the information you need here. See you at Amelia.
#3075
Making progress ! We have received some wonderful photos from fellow Arnolt Bristol owners and will soon have a car on loan that we can make some templates from for sheet metal fabrication. Our next search is for a good used rear differential, the corrosion in #3075 has made the gears and components completely useless. The gearbox has suffered from overheating as well and needs some critical parts.
3075
#3075
We are having some very good luck with rounding up the items we need for #3075, still trying to determine the source for the dash mirror, and also the rear license plate lamp assembly!
Arnolt Bristol parts
Mirror, see my other post. Rear light is Lucas 469, very usual in same period British cars. Repros available and NOS now and then on eBay. Jaguar was one of the brands that use them. If you need a pic of one send me an email to
Ivivancos@austin.rr.com Cheers, |
AB grille
I noticed you are restoring 3075 and I am restoring 3040. I also need a grille since mine is not correct. did you have any luck with a pattern or building one. I am curious what you found.
#3075
We had to custom make ours to fit the car and it likely would not fit another exactly the same. A good metal fabricator could help, but would need access to the car in order to make it fit precisely. Going to try and post photos of #3075 as it's been completed and will be shown at Pebble this coming weekend!
3075 almost done
5 Attachment(s)
My pictures are before the seats were put in. Send me what you have by e-mail and I will post them.
| All times are GMT. The time now is 08:00 AM. |
