Go Back   Bristol Cars - Owners and Enthusiasts Forum > Bristol Forums > About this site - BristolCars.Info
** Known Problems and Updates **
Old 29-07-08, 10:21 PM
devadmin devadmin is offline
Administrator
Default ** Known Problems and Updates **
Unless you have only just joined us you are probably aware that we have a problem whereby html code (gobbledygook to some) is appearing at the beginning and end of some email notifications for new posts or threads.
This appears to be an intermittent problem which makes it all the more difficult to solve. While we are working to fix this you may notice some changes to the email notifications as we try to identify the problem.
If it becomes unbearable, please go to "Member Options" > "Edit FORUM Subscriptions" and change your notification subscriptions.
This link should take you there;
http://www.bristolcars.info/forums/s...ms.php?do=list
Thanks for you understanding.
Old 05-08-08, 10:56 AM
Kevin Howard Kevin Howard is offline
Decorator
We believe the problem mentioned below is now fixed.
There are no known "problems" with the site at the time of writing.
Old 01-09-08, 07:05 AM
Default Attachment Image Size Limit Increased
The image size limit when adding an attachment to a post has been increased to 1024 x 768
The file size limit remains the same at 400Kb but this is more than adequate for web site display.
The relevant FAQ articles will be updated shortly.
In the mean time, if using the Microsoft 'Image Resizer' the 'Large' option will convert images to 1024 x 768 and optimize the file size.
Old 08-11-08, 12:48 PM
Default Problem viewing attached images
There seems to be a problem viewing attached images by clicking on the thumbnail. I'm on to it!
Old 10-11-08, 05:11 AM
This has been fixed now. If anyone notices any other problems please let me know.
Thanks,
kevin
