408 Carbs
Old 25-06-12, 01:43 PM
408Berlin 408Berlin is offline
Cool 408 Carbs
After 2 years in Poland my 408 is back on the road. The body of the car is in a better than new condition now. The guys in Poland did an excellent job for small money. Will post some pics.
But after two years my carburettor is not willing to work correctly. I think it might be a clever idea to buy a new one than to overhaul the old one. It seems new Edelbrock carbs are quite cheap - 300 - 500 €
No my question - should I take the same type of carb again or are there carbs which might fit better? Any experience?
Thanks Hans
Old 25-06-12, 02:36 PM
pasini s pasini s is offline
Hello Hans,
I had your same problems and I bought a NOS Carter 3131S on eBay for about Euro 150 2 yrs ago after many unsuccessful attempts to adapt several Edelbrocks. They were good carbs but the need to adjust linkages, air filters etc made it all a bit too tricky for me. I'd try to overhaul your original Carter using the kits that are available from several US specialists.
Stefano
Old 25-06-12, 10:43 PM
Hans,
There have been a few discussions on here about carburettors in the past, here's one that might help http://www.bristolcars.info/forums/8...l-407-8-a.html
Or click here to do a search
Old 26-06-12, 02:28 PM
Sounds good, your information is exactly what I hoped to get...
Old 26-06-12, 02:33 PM
Thanks Kevin, with that information I guess my problem is solved.
carburettor 408
