603S2 Distributer
Old 30-04-11, 01:40 PM
will7262 will7262 is offline
Default 603S2 Distributer
i have discovered my dizzy has points with vac. advanc. I thiught these came with an electronic distributer? well that what I have read.
Obviously I want a fully electronic device so can anybody advice on the options or if they have experience regarding this?
Old 30-04-11, 05:35 PM
Banned
Default A distributor, or Electronic Ingnition Upgrade
I am not familiar with the model you have, but if it's drivetrain is either a small block or big block Chrysler product, it is a simple matter to use your same distributor and install a Pertronix ingnition. This small device fits inside your stock distributor and converts it to Electronic. It will also use a coil (they have an excellent one) or your stock one. Their coil will handle a full 12 volt charge, giving much hotter spark, whereas your stock coil must run at a lower voltage to prevent it from overheating, but you can use the stock coil on this system, and keep your voltage dropping resistor in line.
Old 01-05-11, 02:56 PM
Default Distributor
Ronald
Thanks for the advice I will look into the sugested system
