411 Rear Brake Caliper & Discs
Old 20-05-10, 05:14 PM
caspian pugh caspian pugh is offline
Default 411 Rear Brake Caliper & Discs
Hello dears,
Anyone know the best way to remove the rear calipers - hubs off or remove rear bottom shock mount. Also does anyone know what else the rear discs fit or have a part number?
Hope to hear from you soon,
CAss.
Old 21-05-10, 02:28 AM
GREG GREG is offline
I will go and check but I think it's the same as a Reliant Robin or was it a Jenson
Old 22-07-10, 09:57 PM
David Olivant David Olivant is offline
On my 408 [and most cars are similar], Chock the front wheels, loosen by
one turn the wheel nuts. Jack up the rear and install axle stands.
release the hand brake, remove the wheels. There are two bolts behind the
brake caliper, using either a socket or a ring spanner, slacken these off.
Clamp the flexible pipe to the rear axle and remove the brake pipes from
the calipers Remove the bolts and remove the calipers. Remove the hand brake
cables.
Hope this assists.
David.
Old 23-07-10, 03:28 PM
Hi David,
Thank you for your helpful advice. The problem is with the 411 that the lower shock mount obscures the rear caliper bolts. This precludes use of a ratchet & even a ball joint extension to loosen the bolts and even in using a ring spanner the withdrawal of the loosened bolts may not be possible with the lower shox mount in place.
Kindest regards,
Cassian
