410 Temperature gauge
Old 09-11-26, 12:41 PM
OakHouse411 OakHouse411 is offline
Default 410 Temperature gauge
Help! My water temperature gauge has stopped working. What thread is the fixing nut union please?
Old 11-11-26, 06:27 PM
From memory, the thread on the nut for the bulb is 3/8" BSP. The thread in the manifold is either 5/8" UNF or 1/4" NPT. They have the same diameter and pitch but NPT is tapered. A straight union should screw far enough in to a tapered hole on the manifold for a decent hold but will need a bit more thread sealant.
Old 11-11-26, 08:27 PM
Default 410 Temperature Gauge
Thank you David for the info
