Window Weather Strip (Drivers and Passengers windows)
Old 29-01-25, 03:50 PM
mgdmurray mgdmurray is offline
Default Window Weather Strip (Drivers and Passengers windows)
Hi
Can anyone advise on where to obtain the correct rubber weather strip that is found next to chrome and glass on a 603. Or any V8 Bristol?
The current "worn" rubber slides along a narrow channel located in the chrome fitting.
Thanks in advance.
Mike Murray
Old 30-01-25, 12:41 PM
It is very likely that Graeme Payne at https://www.classicbristolcarpartscompany.co.uk/ will have exactly what you are after and may indeed be able to suggest an upgrade
If that fails https://coh-baines.co.uk/ offer an astonishing array of rubber sections
