Diff Oil
Old 13-08-24, 12:10 PM
Default Diff Oil
Can some one please tell me what Diff Oil & Gear Box Oil I should use on a 1970 BRistol 411 Mark 1 with a 3 Speed Auto Box??
many thanks
Old 13-08-24, 07:29 PM
ATF+4 and Dexron III seem to be widely recommended for use in the Torqueflite 727. I have chosen Comma MVATF+ as it is readily available from Halfords amongst others.
Do you have a limited slip diff in your back axle?
Old 14-08-24, 08:12 AM
[quote=David C;13470]ATF+4 and Dexron III seem to be widely recommended for use in the Torqueflite 727. I have chosen Comma MVATF+ as it is readily available from Halfords amongst others.
Do you have a limited slip diff in your back axle?[/QUOTE
Hi David,
thank you for coming back to me.
Yes the Mark 1 was fitted with a limited slip diff
Many thanks
Martin
Old 16-08-24, 07:10 AM
Hello Martin.
I contacted Morris Oils to check what they recommend for your rear axle. They suggest their XEP 80W90 is what you need.
Old 16-08-24, 07:41 AM
[quote=Martin9645;13471]
Hi David,
Many thanks
Martin
Hello Martin.
Thanks David,
really appreciate all your help.
Kind Regards
Martin
