Ignition Key
Old 29-07-24, 10:42 AM
Default Ignition Key
I am trying to track down an ignition key for a 411 Mark 1 (1969/70)
The current key is a Neiman dont know if this is original or not???
Am after either a key or a blank which I can get cut
Old 29-07-24, 12:31 PM
I believe the ignition lock on 411s are the same as an early Range Rover
Old 30-07-24, 03:49 PM
Green411 Green411 is offline
If you're in the UK then Timpsons can cut a new one. When I bought my 411 S3 I got them to copy the full set.
