410 Torque Converter
Old 29-05-23, 04:31 PM
OakHouse411 OakHouse411 is offline
Default 410 Torque Converter
Help Appreciated please.
I am looking for a torque converter and flexiplate for my 410. The engine has to come out due to crank shaft wear in the vicinity of number 3 thrust washer. There was 1/8" end float. On an automatic this is very strange and seems to be normally caused by flexi plate mis-alignment or wear in the torque converter. I have a new crank shaft ready to go in.
Does anyone please have the part numbers of the torque converter and flexiplate so that I can order the parts ready for when the engine comes out. i feel that it is prudent to replace torque converter and flexi plate when the engine is out. I am in the U,K,
Thanks in advance
Andrew
Old 30-05-23, 04:02 PM
David C David C is online now
Hello Andrew.
Not sure of part numbers but you are looking for a converter for A727 Torqueflite with stall speed of 2000RPM.
If you get stuck I can help with parts. I have just removed original gearbox, converter and flexplate and replaced with overdrive items. I had half a mind to keep them as spares but would rather they help keep another 410 on the road.
