Ignition Coil
Old 14-06-22, 10:32 AM
OakHouse411 OakHouse411 is offline
Default Ignition Coil
Hi there
Can anyone please tell me the correct replacement ignition coil for my Bristol 410. I am running the standard set up with points and not electronic ignition and am in the U.K.
Old 14-06-22, 11:51 AM
AndrewA AndrewA is offline
I've got a Mallory one on mine - ref 29219.
Old 14-06-22, 01:15 PM
thank you for this info
Old 16-06-22, 09:23 AM
Any good quality 12V coil will be suitable provided it is suitable for use with a ballast resistor. I read once that Chrysler took to using ballast resistors to improve the longevity of the points. By the way the resistor is already in the ignition circuit
Old 16-06-22, 04:54 PM
thank you for this info. There is nothing wrong with the one that I have. I just feel that a spare would be a good item to carry.
