410 Oil Filter Conversion
Old 23-07-21, 10:56 AM
OakHouse411 OakHouse411 is offline
Default 410 Oil Filter Conversion
Hi All
I have a problem with an oil leak in the region of the spin on oil filter.
The conversion kit was supplied many year ago by SLJ. The leak is not between the conversion kit and the engine block, but appears to be between the filter and the conversion kit. I have changed the oil cooler hoses and replaced the filter and sealing ring but it it has made no difference. The oil filter conversion seems very similar to that for an MGB. Question, will an MGB filter conversion fit ? Any other words of wisdom much appreciated
