408 original air cleaner dimensions, please?
Old 07-03-21, 08:12 PM
dwomby dwomby is offline
Default 408 original air cleaner dimensions, please?
My car's non-original Chrysler 360 is currently fitted with an Edelbrock performance air cleaner.
Under acceleration, it is quite noisy. I want to forego this one's excellent throughput for something quieter but have been struggling to find something suitable that fits. Can anybody give me the diameter and height of the original factory fitted air cleaner, please? Does anybody know if it was a standard Chrysler item of that era fitted to some of their models? Thanks.
s-l1600 (18).jpg (352.2 KB, )
Old 09-03-21, 05:16 AM
David No One Seems Willing To Help Possibly Because You Have A Non Original Motor That May Be Different To The Original. I Will Pass On My Experience With My 411 And 412. The 411 Came With A Standard Air Cleaner With The Standard Cast Iron Manifold Which Holds A Lot Of Heat. I Decided To Replace The Manifold With A Second Hand Alloy Holley Manifold. Great Until I Fitted The Original Air Cleaner And Discovered The Bonnet Would Not Close. I Note You Motor Appears To Have An Alloy Manifold.the Standard 408 Air Cleaner Is Quite Large Which Could Causes The Front Of The Air Cleaner To Hit The Bonnet So You Need To Check Closely Your Measurements.
In The Short Term I Found A Standard Round Air Cleaner With A Lowered Base Plate Which Gave Me The Clearance I Needed. Later On I Had The Top Of The Manifold Machined Down About 1/2 An Inch And I Can Now Just Close The Bonnet .
The Original Air Cleaner Certainly Reduced The Intake Noise Quite A Bit. All This May Not Apply To A 408.
Old 09-03-21, 05:18 AM
Sorry about the capital letters . I typed it all in capitals and the software changed it to upper and lower
Old 09-03-21, 06:50 AM
AndrewA AndrewA is offline
Morning - I must admit I was only holding back as I'm unable to answer your specific question. As I may have told you I've got a 410 with a 318 in it. It's got an Edelbrock carb on it and a big circular aftermarket pancake filter. With that set up I only get any induction noise on kickdown and personally I don't find it unpleasant. When pottering/cruising it's quiet. This is helped massively by the other big improvement from when I redid the heater matrix and fan motor last year. Encouraged by Roger on here I paid a lot of attention to re foaming/re sealing all the various joints and gaps and so on between the engine compartment and the interior. I found it a painful process but it has transformed the driving experience - most noise (and occasional smells) now stay outside where they belong.
Old 09-03-21, 12:01 PM
Thanks, Andrew. It looks like that's the kind of air cleaner I will end up fitting subject to finding one that will sit low enough. Good pointer on the heater seals for future reference too!
Old 09-03-21, 12:14 PM
Peter, thank you so much. I have been mocking up a few sizes of aftermarket air cleaners (the pancake type with opening all round) and used snorkel types from Chrysler cars of the 70s (my engine dates to 1978). This showed anything that sits 3" high on top of the carb and has a diameter of more the about 10" will hit the bonnet! I couldn't work out how the original air cleaner could possibly have fitted!!! I had started wondering if the 360 engine was taller or had been fitted on mounts that were higher because something was clearly different from the factory set up. Your explanation of the intake manifold being higher provides the answer and, looking at the drawings in the spares manual, I can now see the difference. Thank you!
The aftermarket pancake types can be had with a lowered base plate. I also see some can be had where the carburetor opening is offset - thus allowing the air cleaner to sit a bit further back over the engine although I think the combination of lowered and offset may result in the air cleaner base sitting on the distributor ! It's a pity I can't buy a few and test fit them!
Anyway, some more mockups and measurement will need to be done but it looks like it will have to be an aftermarket pancake type that I fit. Hopefully it will help to reduce the noise a bit.
Old 10-03-21, 01:15 AM
I love originality and went to a lot of trouble to get my original air cleaner to fit. Could i suggest you try and borrow an original unit and see if there is any way you might get it to fit ( eg machine the top of the inlet manifold or cut out part of the base of the filter canister and raise it which will lower the unit overall ).
As I said I know little about the earier V8 cars but a quick look at photos on Google indicates the 408 had a smaller but higher unit than the 410.
By chance how thick is the gasket/ block between the carbie and the inlet manifold. I found a very thin but effective one made by Holley which did the job.
Old 10-03-21, 02:59 AM
Peter, thanks but I doubt I can find an original air cleaner to try that. I am in Florida and Bristols are a bit thin on the ground here!
I do take your point that there may be ways to make something original looking fit the car and I may resort to some. However, the engine is not original anyway (it's a 360 from a 1978 Dodge Monaco) and, I have discovered today, it has a 'hotter' performance camshaft fitted. So I am not sure now how much I should interfere with the breathing in trying to make it look original. My main objection to the current air cleaner is noise when opening the throttle.
I'll keep working on it.
Old 10-03-21, 07:47 AM
I dont actually know but I am sure the unit would be off a chrysler car of that era. Your engine bay and motor looks very tidy and well presented but the air filter is just not BRISTOL.
Old 10-03-21, 08:02 AM
These are 2 I found on Google Search. Could be MK 1 and MK 2 .Some forum member could surely post a picture of their car or have some knowledge.
The demand for original air cleaners and manifolds in the US is very strong as people would pull them off their cars and throw them out. Crazy prices are being paid for Big Block parts.
408 AIR CLEANER.jpg (102.6 KB, )
408 AIR CLEANER 2.jpg (82.7 KB, )
Old 10-03-21, 08:03 AM
For want of something better to do was just looking at Dodge Monaco engine bays and the original air filter box on those looks more subdued/period than your current hi-flow arrangement and would certainly be quiet. I suspect it might need some modification to fit but I'd probably start from there if it was me.
Impressed with neatness and cleanliness of engine bay! I also have one of those bling alternators - also inherited!
If you're already way ahead of me on the air filter box, apologies.
Old 10-03-21, 11:22 AM
........... the air filter is just not BRISTOL.
I know! It just looks wrong in there, doesn't it?
I took a few more pics. It looks like there is some sort of mounting plate below the carburetor. If I can remove it, it may give me an extra 3/8" headroom.
I am unfamiliar with US V8 engines but the carburetor itself seems HUGE. It's this one: https://www.summitracing.com/parts/sum-m08600vs
As you can see from the side view taken from outside the engine compartment, the existing air cleaner barely fits. I'm really constrained by the height of the big carburetor sat on top of the high intake manifold.
Old 10-03-21, 11:23 AM
I'd be very happy with either of those if I could fit one.
Old 10-03-21, 11:25 AM
Thanks, Andrew. I will find some way to fit something more appropriate as an air cleaner.
I wish I could claim credit for the engine bay but it's the work of the previous owner. I will be challenged to keep it looking that good!
  #15
Old 10-03-21, 12:03 PM
My guess is that the carbys that fit any mopar LA series or B/RB V8 will have the same top diameter (where the air cleaners sits). The Edelbrock on my 411 (B block 400) has a top outer diameter in just under 127.5 mm, so 5 inches. The flange on which the gasket sits, then the air cleaner, is about 5mm wide. The original Mopar air cleaners probably varied depending on the body type.
The air cleaner on my Bristol 411 is 90mm high, although the bottom is recessed, so the effective height off the top of the carby is 81mm. It looks lower in height than the original one fitted to the 408, but it is also wider, so that might be an illusion.
Mine also is also a dual snorkel version like this, whereas I believe the standard 360 air cleaner and the original one on the 408 are single snorkel, but from photos on the web it's clear that you could get a dual snorkel air cleaner for the 360.
As it happens, while I was taking measurements I noticed that the air filter on my car is about 4mm too high for the housing (another bodge by the guy who rebuilt my engine). Although, because the filter seals against the lid, too high is better than too low, so long as the bonnet still closes!
David, the crucial measurement for you is the height of the threaded post that goes up through the middle of the air cleaner. That determines the maximum height of the air cleaner, less the nut that secures the air cleaner, although the air cleaner lid is typically recessed in the middle. On mine, the post protrudes about 3mm higher that the highest point of the air cleaner (even with my 4mm oversized air filter). It is difficult to measure the distance between the top of the post and the flange on the top of the carby, but I'm sure its possible with a bit of mucking around. That will give you a very good idea of what you have to play with in terms of air cleaner height.
Bear in mind, that post can easily be cut shorter, so it might not be as high as it could be on your car. It could have been cut down to suit the current air cleaner. It would be interesting to know the clearance between the top of the post and the bonnet. Of course it's very hard to see, unless you could position a camera in the engine bay to give you a visual while the bonnet is closed. Alternatively perhaps you could tape a small slab of plasticine to the underside of the bonnet to see if you get an imprint from the post.
  #16
Old 10-03-21, 12:22 PM
Thanks. The carb has what seems to be considered 'standard' throat size for a 4 barrel carb here - 5 1/8" or, I calculate, 130mm (Sidenote - I am Brit born of an age when we learned 'imperial' units of measurements, then went Canada and became modernized to the metric system but now I am in the US most of the year and EVERYTHING is back to 'imperial' (except they call it 'US' and have smaller pints and gallons))
The threaded post for the current air cleaner is VERY short as its retaining nut sits within the air cleaner at the bottom!! I like the idea of using plasticine to establish what clearance I have. However, my challenge is not over the centre of the air cleaner or to its rear or sides. If you look at the 3rd pic I posted above, you'll see the front of the current air cleaner will almost touch the bonnet when it's closed. That front edge is about 4.5" / 115mm forward of the center of the threaded post holding down the air cleaner. So a round air cleaner of the same overall height (3" / 76mm) could be a maximum of 9" / 230mm diameter before hitting the bonnet. Anything of larger diameter needs to be lower. Yes, there are air cleaners with recesses so they sit lower on the carb but so far, I haven't found one that will sit low enough to avoid hitting the bonnet and/or not interfere with the throttle linkage and/or electric choke.
I'd love to fit a round air cleaner with one or two snorkels but I am beginning to doubt that will be possible. I'll keep working on it.....................
  #17
Old 10-03-21, 12:26 PM
David,
I've just looked at some of the photos you posted and your air cleaner sits up quite high above the flange on top of the carby, whereas some original style air cleaners start below the flange because the bottom of the air cleaner is recessed.
Hopefully the attached picture of mine will give you an idea of what I mean.
I believe there is a good chance a standard Mopar air cleaner for the A (LA) series 360 engine will fit under your bonnet, or should I say hood!
If you buy a secondhand one on eBay, if it doesn't fit you can always sell it again on ebay
  #18
Old 10-03-21, 01:32 PM
David,
This one looks like it sits quite snug https://www.forbbodiesonly.com/mopar...01-jpg.532225/ .
For what it's worth, the height of your carby is the same as mine - 3.250 in.
Also bear in mind that the bonnet is higher in the middle than it is at the sides where it meets with wings.
If you are prepared to take the plunge and buy a secondhand one on eBay, at least you are the in the right country . If you do find one that fits, you can probably get a replacement post for the centre of the carby. It looks like you could buy a period single snorkle air cleaner for around $100.
  #19
Old 10-03-21, 02:55 PM
Here's a mockup I made of a 17" dual snorkel 3" high that I considered buying.
It might work if I can lower it but probably more likely to fit if I use a 14" dual snorkel. There are separate lowered 14" bases available. Maybe I could cut the base out of a factory dual snorkel one and rivet/solder one of the lowered ones in its place. I'll play with mocking that up today.
  #20
Old 10-03-21, 09:19 PM
Interesting found on Austrslian Ebay
https://www.ebay.com.au/itm/Mopar-do...8AAOSwfD5dTqA7
