Winterburn CDI installation on 408
Old 01-09-19, 06:22 AM
Fund_Man Fund_Man is offline
Smile Winterburn CDI installation on 408
I have ordered a Winterburn unit from Fred Winterburn in Canada. Fitting should be very easy but I need identify the type of tacho (Smiths RVI?) and locate the tacho wiring so i can install a bridge rectifier. Fred has advised that the tacho won't work without the bridge which is simple once I have found the wires etc.
Has anyone fitted one of these to a 408 Mk1......or similar. I suspect not but I thought I'd ask just in case someone could help.
Many thanks
Ian.
Old 01-09-19, 11:03 AM
I think there is a wiring diagram for the 408 in the resources section as I remember seeing a previous post with this attached.
Old 01-09-19, 01:02 PM
There is indeed, it's here;
Resources - Bristol Cars - Owners and Enthusiasts Forum
Old 01-09-19, 06:38 PM
Thank you. I only had a black and white one in a manual that didn't specify the model it referred to so this will be very handy.
408, electronic ignition, tachometer, winterburn
