Rear Shock leak// 411 Series 3
Old 20-05-15, 06:07 PM
richardgray richardgray is offline
Default Rear Shock leak// 411 Series 3
Am wondering if anyone can throw some light on leaking differential fluid from rear shock? Is this "normal" or even just my imagination? Thanks so much for any advice.
Old 20-05-15, 09:05 PM
Richard the diff fluid is self contained in the diff. The diff has a gasket on the rear plate and a seal on each of the input and output shafts.
The shock absorbers also have their own self contained fluid.
Maybe what you are looking at is the self levelling system. From memory this was introduced on the 411 S3. That often leaks and isn't really much use. There's a reservoir and pump for this in the engine bay, which you can safely remove.
Can you post a picture of the offending leak?
Old 20-05-15, 09:14 PM
Thanks so much for this. I'll get a photo too...
Old 23-05-15, 08:12 PM
Default self level
kevin sorry to correct you but the series 2 411 was the first with this feature
Old 23-05-15, 09:24 PM
Bryn Tirion Bryn Tirion is offline
I presume that by self-levelling system you mean something quite different from the Armstrong Select-A-Ride, fitted to 408's and possibly earlier? That was certainly problematic and I believe always removed.
Old 23-05-15, 10:12 PM
Yes Bryn, it is a real self levelling system with its own engine driven hydraulic pump.
Old 23-05-15, 11:54 PM
Thanks for that.
