Removing the steering wheel on a 410
Old 19-12-14, 11:45 AM
livermoreb livermoreb is offline
Default Removing the steering wheel on a 410
Can anyone please advise how to remove the steering wheel from a 410?
I need to get at the wiring behind the dash but to do that requires the removal of the steering wheel. I have taken off the centre cover with the horn push expecting to find a nut that would release the wheel but there is nothing but a circlip. I have tried pulling the wheel but it is not moving at all.
There is a metal ring behind the wheel with 3 holes around the circumference. Is that holding the wheel on? I have tried to move it but had no success.
Any advice would be appreciated.
Old 19-12-14, 02:26 PM
Barrie Barrie is offline
The aluminium ring behind the steering wheel is the adjuster to enable the reach of the wheel to be altered. Take a 'C' spanner and apply it to the ring and turn it anti-clock-wise to release it.
You will then be able move the wheel nearer or further away but it will be stopped from coming off by the circlip which then needs to be removed to enable the wheel to be removed.
Old 20-12-14, 12:43 PM
Brilliant, I got a C spanner this morning and have now got the wheel off. I had to turn it clockwise to losen it and the wheel came off easily.
Many thanks for your help.
Old 20-12-14, 03:16 PM
Angry
Good.
I must have been standing in the engine bay when I last did it.
Old 20-12-14, 06:11 PM
Angry
Old 30-07-25, 11:31 AM
Sleigh Sleigh is offline
As a new owner of a 410 I have a steering wheel off job.
I saw the 3 indents on the ring behind the wheel, on mine they've taken a bit of a battering over the years, I tried using a copper drift and giving it a good session of percussion engineering but it's still stuck fast.
Couple of questions,
1. Are they normally stupidly tight?
2. Schoolboy question....I'm assuming conventional thread and it's going to undo clockwise looking at the front of the wheel/anti-clockwise looking at the back of the wheel.
3. Am i likely to drift it off rather than making a c spanner.
Thanks in advance.
Old 03-08-25, 10:02 PM
If they haven't been undone for a while they can be quite tight.
They are conventional right hand thread.
I suggest making a decent C spanner with as much engagement as possible. Drifting it off will be messy and make life difficult in future.
