Bristol 400, 1950 question about a button
Old 08-07-13, 05:28 PM
Rombrand Rombrand is offline
Default Bristol 400, 1950 question about a button
Dear all,
I have just bought a nice fantastic Bristol 400.
My question is about the button "CARB". Can someone explain what that button is about and how to use it.
Thanks Roman
Old 09-07-13, 01:38 AM
Ex Member
Push or pull the button...then turn the key and perhaps pull the choke. Motor will start and you will then turn the switch off.
It powers a solenoid that feed fuel to the manifold. Will NOT work if you try to operate it with the key on first!
Dorien
Old 09-07-13, 02:43 AM
Roman ,
Congratulations on your purchase. What carburettors are fitted to the engine ?? Solex or SU
The Carb button is a switch to a Solenoid which activates an enrichment device incorporated with the float chamber of the front SU carburettor only .
It will only work if the ignition is on .
There is also a Mixture button which operates a pull cable to a lever on the centre SU carb .
The rear carb has no enrichment /coke device fitted.
In cold weather from a cold start you usually have to activate both buttons , if it starts without it indicates the carbs are set way too rich.
If three Solex cabs are fitted the Carb button is not used , only the Mixture cable .
Could you please advise the chassis and registered number of the 400 and post a few photos on the Forum or direct to me to update the 400 Register
Geoff Dowdle
BOC Joint 400 Registrar
Old 09-07-13, 05:23 AM
Ho Dorien,
thanks for the explanation. A last question regards the button if you do not mind. What is the purpose of the button and when should it be used?
Thanks and have a great day!
Best regards,
Roman
Old 09-07-13, 05:28 AM
Goeff,
thanks for the feedback. I will post some pictures in the next days. Best regards Roman
Old 09-07-13, 05:30 AM
Geoff,
so in other words, if it is a Solex Carburettor the button CARB does not have a function, it only works with a SU carburettor?
Best regards,
Roman
