wood rim steering wheel for 403
Old 02-12-12, 09:07 PM
ronp ronp is offline
Default wood rim steering wheel for 403
I have grown to like the feel of wood-rim steering wheels and I would like to evaluate one on my 403. I suspect that appropriate splined hubs will not be currently availble, so does anyone know what else would fit? I have the facilty to machine up a suitable donor hub so as to accept a standard 4" bore wheel. I do not want to modify the original wheel hub as I realise wooden rims are not to everyones taste- I want any future owner to be able to revert.
Ron Palgrave
Old 02-12-12, 09:19 PM
HughMiller HughMiller is offline
I've got a spare wheel with a badly corroded rim you could have.
Hugh Miller
Old 02-12-12, 10:25 PM
Thanks very much! for arrangemenmts, my e-mail is ron1944@tiscali.co.uk.
Old 03-12-12, 10:57 AM
Bristolian Bristolian is offline
Hi Ronp
It looks as if your problem has been solved, however if this turns out not to be the case, I have traced another spare wheel which one of our members has, should you need it.
John Lawley
Spares & Technical Support Officer
BODA
