406 with engine change
Old 12-12-11, 07:34 PM
rover12t rover12t is offline
Default 406 with engine change
hello
I have bought a 406 without engine gearbox
I can't aford to by replacement ubnit, so I have installed a Rover 2600 with an automatic gearbox
what I need to know is with the difference in back axle ratio's and different wheel sizes, whether I need to have the back axle ratio chnaged or not
help please
Old 12-12-11, 07:43 PM
Richard Levine Richard Levine is offline
Default 406 engine and gearbox change
Hi Mike
Why did you choose the Rover 2600 engine and gearbox? A 406 with non-original drive-train; how bizarre is that?
Richard
Old 12-12-11, 07:48 PM
Banned
Default Rear end gear ratios
Best advice would be just to try out what you have, and then decide if you want good acceleration or better fuel mileage. Different strokes, as they say.
No worries on changing out engines. Look at all the Vee Eight cars with Chrysler engines in later years. Original, eh?
Old 12-12-11, 07:52 PM
Ex Member
Measure the outer diameter of the wheel on the Rover and if is close to the Bristol one, you should be good to go.
Ratios vary and it often boils down to the kind of driving you are used to. A road test will confirm this.
Note that your speedo and tach may not work as they will have been geared for a different sending unit.
Have fun!
Dorien
Old 12-12-11, 08:19 PM
GREG GREG is offline
Originally Posted by Richard Levine View Post
Hi Mike
Richard
I agree, very bizarre !! Although I heard that a few people dropped a 313 Chrysler in their perfectly good 406's. They reckoned it almost doubled the horse power and torque and made it as powerful as other top cars of the era !
They all clubbed together and decided to call it a 407
I like the Rover 2600 engine - It powers my lawn mower beautifully
Old 12-12-11, 08:35 PM
But seriously folks
We all know that a lot of good and restorable Bristols have had their engines robbed to keep toys running. A crime in my mind but I understand why it happens.
I think it is fantastic if the cars that have had the drive train robbed are kept running with any drive train.
After recently seeing an all new Bristol 6 cylinder engine that is being manufactured by NG racing in Nottingham, I believe that eventually the cost of these engines will be financially viable to be installed into cars that have been kept on the road with spurious drive trains. It will make the restoration back to standard a lot easier if the car has been maintained well and kept on the road with whatever engine the owner is happy with.
Good to see, and probably drives every bit as good as a 406 with the original engine.
It's a shame that Clyde didn't get to finish his similar project.
Old 12-12-11, 09:11 PM
desmolloy desmolloy is offline
Default Rover 2600
Hi Mike, very keen to follow your findings. I also have an engineless 406 and have considered a Rover 2600 repower as the engines have very little value here in NZ and are probably quite reliable and a good cheap solution in the interim while we wait for the correct engine to present itself. I can be contacted off-line on desmolloy@gmail.com if you care to compare notes etc
Des Molloy
Golden Bay
New Zealand
Old 12-12-11, 10:11 PM
Banned
Default Engine swaps in the older Bristols
Now the conversation is getting interesting. I was thinking that a very modern, high output engine can be had from Japan. The Nissan 6 cylinder inline engine would have the advantage of light weight and terrific performance coupled with that bullet-proof reliability the Japanese products are noted for. Their manual transmissions are among the best ever produced. You may buy the front half a car with low miles for about the price of any engine you would care to name. As to a new Bristol 6, well, without extensive testing and limited resources to develop a new engine, I would think it would be a gamble at best. Surprisingly, some people are happy with any car that is able to move under it's own power, regardless of the source. As far as originality is concerned, there is nothing original about these cars, and we can thank the Germans for what little the cars have to offer.
Old 12-12-11, 10:46 PM
[quote=R As to a new Bristol 6, well, without extensive testing and limited resources to develop a new engine, I would think it would be a gamble at best. Surprisingly, some people are happy with any car that is able to move under it's own power, regardless of the source. As far as originality is concerned, there is nothing original about these cars, and we can thank the Germans for what little the cars have to offer.[/QUOTE]
NUTTER ! Do you really think an engine would be developed by people that don't know what they are doing ? In fact it has certain improvements and everything is interchangeable with the original and is built with modern stronger metals. Mainly developed for race cars that use the Bristol engine and much stronger than the original.
To a certain extent we can thank the Germans but the Germans didn't build any Bristol cars and Bristol made a number of improvements to the point that Bristol engines are sought after by vintage BMW car owners.
I am starting to realise that you know very little about cars, especially Bristols
Old 12-12-11, 11:06 PM
Banned
Default Engines and origins
That may be true, in that development can improve upon a design that goes back a number of years. Take the Porsche engine, please! An excellent example of the bumblebee approach to making a potent machine. Others have succeeded in making silk purses out of a sow's ear, but that does not make it a good approach. The Mazda/Wankle is another sterling example of what stubborness can do. If you want to see a brilliant six cylinder design, you need look no further than any BMW so equiped, and there are thousands of examples that hardly ever self-destruct. Tried and true is not a bad concept. Having had more than one man's share of what is out there, I believe I have a fairly good idea of what's what when it comes to cars.
Old 12-12-11, 11:21 PM
If that is true - and I doubt it, I don't think you have convinced anyone on this forum with your pointless ramblings.
How can you compare Porsche continuing to develop the Boxer engine with people making a recreation of an engine that was retired in the early 60's to enable historic race cars to keep racing ? Wrong again !
Bored now
Old 06-01-12, 11:23 AM
Michael English Michael English is offline
Smile Not cricket chaps
This is a forum for helpful conversation about the cars which intrigue us, lets be pleasant!
My original 401 (80C ?) engine is presently giving me a little grief, but being new to them I take everyone's word that when going well they are a joy & I look forward to experiencing this.
People will clearly rob a scruffy Bristol for its powertrain if their preference is to sort out something more desirable or valuable, perhaps an AC Aceca. Arguably this is less of a crime than robbing a Rover 3500 V8 SD Vitesse manual and shoe-horning it into a Ford Escort or some such.
Who knows why Mike has obtained a 'gutless' Bristol, it happens. I totally agree that it is far better to have a Bristol running about with, for now, something 'wrong' under the bonnet. I saw an Aston Martin DB4 at auction with a Jag straight 6 under the bonnet, and it looked perfect. I am sure the Bristol will drive fine with Rover bits and as Mike seems to have a Rover affinity, its perhaps the right choice for him. If it was me, I think I'd look for a Jag engine, the most economical straight 6 I could find, as I think it would be better suited & would also look pretty good when the bonnet is open.
The Nissan 3 litre straight 6 is pretty much direct theft from the very similar engine used in the Austin Healey 3 litre ... it will also look great under the bonnet as long as any Nissan badging is removed !!!!!!!!!!!!!
May I plead for friendly & constructive criticism only, it makes the forum a joy to visit.
PS, its wonderful that a 'new' Bristol 6 engine is available again .... I rather dread to hear how dear it will have to be, but perhaps no more than a full-on rebuild of a tired engine. Can anyone steer me toward an engine guru in Somerset (ideally Yeovil/Taunton area) as mine is blowing smoke
. Reason: PS
Old 05-06-12, 12:18 PM
john john is offline
Here is a highly tuned original Bristol engine that would make the 406 go pretty well. Its not a 2.2, so it might lack some low down.The price is spectacular!
AC Bristol sports/racing 100D engine | eBay
Old 05-06-12, 03:35 PM
Banned
Default The Bristol engine for sale
Spectacular price is a very good description. Spectacular in what they are asking for it. It might be interesting to find out what their intentions are for a replacement in their car. One could purchase a car for that amount of money. We see the same thing in the States when people try to sell a racing engine that was purpose-built to run at high RPM to make that much power. For the street,one would have to re-do the engine, lose the high compression,the wild camshaft and all the rest. But, there are people out there who would not take any of that into consideration. The real estate people love to use the phrase, "There is one in every bush".
  #15
Old 22-06-12, 07:16 AM
The price is relative to the market value of the car it came out of - an AC Ace, which is where such an engine belongs, or perhaps in a Cooper Bristol.
It is after all described as a racing engine so I doubt very much that the owner is expecting it to be purchased to go into a Bristol saloon!
I notice he has another one for sale at £18,500 that just needs assembly.
The sad reality is that of all the cars such engines were originally used in, the Bristol is generally worth the least, perhaps with one or two particular exceptions. That is why tatty 6 cyl Bristols are bought for their power trains, to be rebuilt and installed in much more valuable cars.
  #16
Old 09-07-12, 01:04 AM
John Simmons John Simmons is offline
I see that this exact same engine is for sale again on ebay at the exact same price. Seems it was a bit too much the first time around, so they will continue trying. Would love to have it myself, but I just can't convince myself that it's worth that much.
  #17
Old 12-05-25, 06:42 PM
Mike406 Mike406 is offline
Des Molloy
Golden Bay
New Zealand
hi
long time since I have followed this up, however due to illness and other Rover projects things have been stalled. so here we are today with a 406 with 2600 twin carb SD1 engine and BW 65 auto gearbox, primarily so my wife could driver but unfortunately she is no longer able to drive.
firstly the car is now running fine but seems to be revving too high relative to the road speed
just over 3000 RPM for 50 MPH
so two thoughts,
should a revert back to a manual, I have a LT77 5 speed box
and / or
should I up the rear axle ratio
any thoughts welcome
by the way I am a rover fan. had several, currently has a 1940 10 coupe, a 1947 16 6 light sea
saloon, a 1967 2000 TC manual and 1 1998 200 coupe had from new
so hence the link to Rover powertrain
  #18
Old 12-05-25, 10:53 PM
A quick google suggests BW65 has a 1:1 top gear in common with the original 406 gearbox but the latter had a Laycock overdrive. It looks as though the LT77 has a .75 or .8:1 ratio in 5th so should be similar to the original setup with overdrive giving 2250 to 2400RPM for 50MPH from your figures.
It's a lot easier to change the diff ratio - if you can find the gears - than it is to convert transmissions so if you are happy with an automatic I would see what axle ratio options are available.
  #19
Old 13-05-25, 07:15 AM
I'll think about options and make a decision for a winter project
thanks for your thoughts
  #20
Old 29-05-25, 08:58 AM
James Eastwood James Eastwood is offline
Mike, just a couple of thoughts before you change your gear box, because 16mph/1000rpm doesn't sound right, that's more MG Midget or Mini territory.
I would raise a rear wheel and count the rear wheel to prop rotationss to check axle ratio.
Then I would set up a multimter to measure engine speed, and use a GPS speed App on my phone, work out the actual ratio you are getting between measured engine vs vehicle speed.
Have you counted the gear changes to make sure it is shifting into top gear? Is the auto box topped up with fluid?
The only explanation I can think off might be if the car originally had say a +15% over drive fitted, some manufacturers would lower the rear gear slightly (maybe 7%) to give the car better acceleration AND better top end cruising. Your auto box I expect will not have an over driven top gear but instead a straight thru 1:1 drive in top.
James
