400-406 polyurethane bushes
Old 17-09-11, 08:35 AM
flyinghorse1 flyinghorse1 is offline
Default 400-406 polyurethane bushes
Where can I get polyurethane bushes for a 406 antiroll bar and the drop links?
(or standard rubber ones).
I am fitting a 406 antiroll bar to my 400.
Graham
Old 17-09-11, 02:30 PM
Ronald G. Stephenson Ronald G. Stephenson is offline
Banned
Default Bushings for a sway bar
Not all that complicated. These are usually on the shelves in bubble packs in most auto parts stores. All you need is the diameter measurement for the bar. Most all are fitted with a simple horseshoe sort of clamp and are quite easy to change out. Take the clamp with you and try some of the different sizes. Of course, the sway arm bushings likely need replaced too. This is that small assembly at the ends of the bars. I like the idea of the durability of the poly bushings, as the firm up the ride and improve handling. Be prepared for some new squeeks from the upgraded bushings. They do not lubricate very well.
Old 19-09-11, 04:08 PM
I think I can get what I need from superflex
SuperFlex Ltd - Suppliers of Polyurethane Car Suspension Bushes
Thanks.
Graham
Old 12-10-12, 05:09 PM
Dean Dean is offline
Graham, did you obain polyurethane bushes for your 406 anti-roll bar in the end? If so, do you have the part numbers from whichever company you bought them from? I am looking for them myself.
J
Old 14-10-12, 09:34 AM
No--406 antiroll bar still sitting on workshop shelf. May get to it this winter.
Graham
