Thinking about a 401/403
Old 31-01-25, 12:04 AM
Raymond Raymond is offline
Default Thinking about a 401/403
I am rather taken with the advert for this early 401 but before travelling down from Derby to view the car, I thought perhaps someone on this forum may know of it?. Has anyone been to see it?
https://www.youtube.com/watch?v=YVr8QLpkfKo
What is there about these early aerodyne models that I particularly need to look out for?
Old 31-01-25, 09:11 AM
First signs are good - it looks as though it has a disc brake conversion.
Check whether it has an anti roll bar and what engine and gearbox are fitted.
Original engine would probably have been 85A at around 80BHP. Later 100A, 100B2 etc over 100BHP and the extra power is useful on modern roads.
It doesn't look as though this one has had an overdrive added but something to look for.
Bristol gearbox may well be good but now hard to rebuild. Later BWCR gearbox is a better prospect.
First signs of rot are usually in front of base of rear wheel arch. Lower the spare wheel carrier and look for corrosion on the sides of the metal on either side.
If you can drive down a hill on the overrun as long as possible then boot the accelerator. As little smoke as possible out of the back is a good thing. An engine rebuild may easily cost £10k
The car should go where you point it and not veer to the sides over bumps. I would suggest you drive all of the available 401s before you make a decision.
Old 31-01-25, 09:48 AM
Stefan Stefan is offline
Default That 401
Well sounds like everything I can think of has been addressed. Scrutinise it underneath on a ramp and look carefully at the new paint e.g. around the wheel arches to make sure no corrosion is striking through.
A compression test would be reassuring but it sounds as if mechanically the engine will be tipi top.
If it hasn’t got an overdrive ( essential for the motorway) and anti roll bar those can readily be fitted.
These days we’re looking at restorations of restorations of a 70+ year-old car so much depends on the skill of the ancestral artisans. Most important of all , finally, I would get it well warmed up and drive it very fast to make sure you enjoy it. Some thoroughly restored cars are mere Trailer Queens, this one via SLJ , BCL, and Hackett has the right provenance, and should be a brilliant drive.
Old 31-01-25, 11:01 AM
Thank you Gentlemen. Some good points to consider.
Here is the advertisement:
https://www.carandclassic.com/car/C1663012
2008 BOC concours winner is a good start!
The car appeals to me on several levels. I particularly like the white faced instruments and the rest of the cabin looks like a nice place to be.
This car has had a fortune spent on it ...and the work has been carried out by all the right people too. This includes a disc brake conversion.
I am finishing a 'last nut and bolt' restoration of an MG TC
but until it is out of the door I can't get too excited about another purchase. I am, however, determined to get a 401/3 one day ...but it would need to be the right car. This one ticks all the boxes but has been for sale for ages; I am just wondering if the price is just too high?
Old 31-01-25, 07:28 PM
It is a lovely looking car. I do like the white faced instruments.
A lot depends on how you plan to use the car. The 2 litre Bristol responds very well to being driven quite hard and can be great fun. If this is how you are likely to use it then you will probably appreciate uprated engine and gearbox. If you are planning to cover large distances an overdrive gearbox will make for more pleasant cruising but make sure that the differential ratio has been changed to 405 spec. This not only makes the car longer legged on the motorway but gets it away a bit quicker too.
There are plenty of good cars available at the moment so follow Stefan's advice. Find good empty roads and get your foot down. You will soon spot the difference between the Trailer Queens and the driver's cars.
Prices are a little hard to judge at the moment. There doesn't seem to be a huge demand from those under pensionable age, many preferring the fast Fords and similar of their youth. This means a decent supply of good cars with less clamour to buy. If you are not in a hurry you could make an offer and bide your time but the really good spec cars may well sell quickly as there are fewer of them.
Old 31-01-25, 08:33 PM
David, thank you for your advise. As it happens I have now reached the age of 70 ...but I am in denial.!!
The MG TC I have rebuilt has a competition history but it now has a supercharged engine built to fast road spec. The car also has a higher final drive ratio and a 5 speed box. Uprated steering and brakes etc etc. so you get the idea. I don't like to dawdle but I would want to fit an overdrive. I had one on my Triumph GT6 and wouldn't really want a 4 speed box without it. It would also give the engine a longer life. Thanks for the tip about the 405 diff.
Old 16-04-25, 08:26 PM
I see the 401 has come back on the market ; I thought it would. Asking £42,500.
I am still working on my MG TC project but the end is in sight.
I shall be re doubling my efforts.
Old 23-04-25, 01:56 PM
MSJ 895 is one of the very earliest 401s and was a regular on the very long distance Bristol Owners Club tours. Think Montenegro, Spain, etc, and her exploits in Argentina are legendary. She was capable, on the lengthy continental BOC tours, of keeping up with with the 5.2 litre Bristol 410 that I then owned (I could get away on acceleration, but she always caught up)
She is, in my view, a beautiful car and was then impeccably maintained by SLJ and it sounds as though she has continued to be looked after by them. When I knew her she came with an overdrive.
I should perhaps make it clear that I have no relationship with the current owner and it is now quite a number of years since I had any dealings with SLJ and Richard Hackett.
I doubt you’d do much better
Old 23-04-25, 03:34 PM
Thank you Roger. That is the sort of information I had hoped someone might post. MSJ 895 is indeed a fine looking example and seems to have been cherished. I am strangely drawn to the stepped sills that seem to give it a special character. Also, the history of a car is so important. It sounds like the car would suit me well.
One worry I have is that the market for the car I am restoring and have invested heavily in; namely a 1949 MG TC, is on the floor at the moment.
I may be mistaken but Bristol cars seem to be holding their own; at least for the time being?.
Old 25-04-25, 06:33 AM
Excalibur Excalibur is offline
There seems to be a very big difference in prices asked by dealers and those that sell by auction. Maybe the dealers only stock the very best and the ones requiring work ending up on the auction sites.
Old 25-04-25, 07:57 AM
Bristol Cars have often performed very badly at auction. I think it may well be due to the cost of fixing a wrong 'un. If you buy at auction you are taking a chance and could end up with very expensive issues. If you buy from a reputable dealer or broker then it is in their interest to help out if on closer inspection post sale the car has hidden issues.
Old 25-04-25, 10:55 AM
Dealers I know won't buy a car unless they can double the price. They also try to gloss over what can be expensive flaws to correct.
He who sups with the Devil needs a very long spoon....
Old 14-07-25, 02:08 PM
Please can anyone tell me if the rear lights on this very early (step sill) 401 are correct ...or have they been altered.??
https://i.postimg.cc/rsr735Yd/1950-b...e2c2db931e.jpg
Old 14-07-25, 03:29 PM
I accompanied this car on a number of European trips and got to know the then owners pretty well. I believe them to be absolutely correct.
  #15
Old 14-07-25, 03:39 PM
Thank you Roger. Any links to past tours etc. that the car has been on would make for interesting reading. Please PM me anything relevant that you wish to remain private.
Thank You.
  #16
Old 13-10-25, 11:12 AM
I see there has been a price reduction from £42,500 down to 39, 500. I presume this reflects the hard reality of the classic car market which seems to be in free fall.
