406 washer and wiper questions
Old 10-04-24, 04:24 PM
Default 406 washer and wiper questions
Please can someone identify the Trico unit in my pictures? I have one fitted to the car above the screenwash bottle but not connected and no obvious loom for it to connect to. I assume it is original as I have another in my parts bin from long ago.
I sill have a vacuum operated windscreen washer unit installed. This has a vacuum pipe from the tank, a pipe to the washer jets and a smaller pipe to the back of the wiper switch. It would be good to know how pressing the wiper switch operates the vacuum wipers.
Also, any idea what the "Electric Coupler" shown on the Lucas wiring diagram does?
Old 10-04-24, 05:26 PM
dwomby dwomby is offline
The vacuum washers in my 408 work like this
pressing the switch connects vacuum to the washer bottle
vacuum pulls up a plunger in the washer bottle
releasing the switch relieves the vacuum and
then spring presses plunger down forcing fluid to the washer jets
Old 10-04-24, 05:35 PM
Do you have to hold the switch in for a particular amount of time?
Old 10-04-24, 05:51 PM
Mine stopped working a while ago and I replaced it with an electric pump but a good 3-5 seconds IIRC
