406 Gearbox
Old 09-07-22, 09:26 AM
AurelienH AurelienH is offline
Default 406 Gearbox Identification
I bought a car several years ago but almost everything is in pieces and there were several cars mixed up.
I wonder if one of the boxes fits my Bristol 406 engine? Because it looks a lot like an MG B gearbox with Overdrive.
Anyone have pictures of this Bristol 406 gearbox?
Thanks in advance
. Reason: change the title - Find more easily
Old 09-07-22, 10:22 AM
Stefan Stefan is offline
Default Bristol gearbox identification
Sadly I'm afraid you are right. This isn't a Bristol gearbox. the 406 has a short gear lever on an extension, and an overdrive fitted making it longer.
Old 09-07-22, 11:31 AM
Ok Thank you Stephan.
Just to be sure before to sell it the gearbox
I need to prepare a stock of gold coins to rebuild my Bristol !
Old 09-07-22, 03:26 PM
The MGB input shaft should work. I use one to line up the clutch when replacing them on Bristol engines. The bell housing would be a bit different, I think.
If you do find a way of attaching an MGB 'box make sure you get one with 4 layshaft roller bearings. This is the weakest part of the MGB unit.
Old 09-07-22, 05:15 PM
Good to know about clutch alignment.
Probably need a plate between engine and gearbox (MGB) and maybe so much modifications (bracket - length of the gearbox ...then length of trans..)
It will be easier if I found a good gearbox for my Bristol.
Maybe inside spare parts bazaar on my garage (Cross fingers but sadly probably not)
