Badges for hub caps
Old 07-01-19, 02:42 PM
Larserik Larserik is offline
Default Badges for hub caps
We are looking for badges to hub caps on a 402. See attached photo.
Doe's anyone knows about the quality on the hub cabs from AM CLASSICS?
I have found a set of four on Ebay but without the badges. They are brand new.
hub cap crest.JPG (829.1 KB, )
Old 07-01-19, 03:31 PM
peterg peterg is offline
They are the same as on the 401. You could also try Bristol Cars spares Dept.
Old 07-01-19, 03:42 PM
fischerhd fischerhd is offline
In 2008 i got 5 badges from Brian May, new, payable and in good quality.
I do not know his email-adress any more, but he is a wellknown restorer and
the biggest collector of bristol cars, a member of the BOC.
I even don“t know if he is in business any more.
Old 07-01-19, 04:54 PM
The AM Classics hub caps are in my view quite reasonable quality in that the chrome finish is good as is the fit at least on the ones I have seen and bought.
I don't know if the chrome is tri plate and it would be worth asking the seller as this can quite important if you use the car in the winter especially on salty roads. The downside is that they are steel, the originals were brass and the material is also thinner. The supplier has two styles of cap one to take the original style of badge and one to take the later flat type. I have also bought 411 hubcaps from them which again look good and fit well and in all cases original badges have fitted these caps perfectly.
The position and size of the lugs on some of the reproduction badges available in the past has varied a bit.
If Brian May can't help I know that Boda have recently sourced all the reproduction badges for the early cars, inc the red ones for the 403, you would have to be a club member to purchase though.
Bristol cars were also able to supply me about 12 Months ago the later flat badges, these are about the same size as the originals, have the same colour background but only the Bristol name on them, not 2 Litre as well.
They were more expensive than the Boda badges but I wanted them for the wheel caps on my 603.
Old 17-03-19, 10:36 PM
zbigmak zbigmak is offline
The BOCA can supply a very good copy of the originals.
