403 Front Wing wheel arch strengthener
Old 31-03-18, 11:09 PM
mikebro mikebro is offline
Default 403 Front Wing wheel arch strengthener
I've had a new nearside wing (just the vertical part) made by a retired panel beater. He has made a fabulous job, all done by hand, including wiring the edge. My question concerns the angled strengthener that fits inside the arch, just above the edge wire. Has anyone fabricated and fitted this? How is it attached? Any information on how to do it gratefully received.
403-1402
Scotland
Old 01-04-18, 01:37 AM
p5b401 p5b401 is offline
Default Redux bonding
An excellent way which does not involve welding or riveting is to bond/glue them.
One such is the Redux bond system which has been used in aircraft manufacture since 1940.
There are several other very successful bonding agents available many of them to do with the car industry.
Old 03-04-18, 09:35 PM
That's what I'll do. I've followed up to see what's available in the UK and Pliogrip seems to be one to try.
Old 05-04-18, 05:58 PM
jasa jasa is offline
Hi Mike
If it's any help, this is what I did with mine - copied what was there.
I assumed it was original ...
003 (2).jpg (394.3 KB, )
Old 05-04-18, 07:52 PM
Originally Posted by jasa View Post
Hi Mike
Thanks Mike. Looking at the photo of the complete front from underneath ,I can see the strengthener is fixed to the wing edge in several places. Is it aluminium welded or glued?
Old 06-04-18, 06:04 PM
Default 403 front wing strengtheners
I welded them in place.
I know modern adhesives are said to be brilliant but I'm to old to be sure.
There was so much work required on my car, I decided to buy a cheap TIG welder and taught myself to use it.
Best
