Which carburetors on a 100d2
Old 18-11-16, 04:51 PM
Noot Noot is offline
Default Which carburetors on a 100d2
I have 3 Weber carbs on my 100D2 engine and I believe they should be Solex 32BI. Is there a lot of difference between the various types of Bristol engine carbs?
I can get a set of carbs 32BI and a stamp with LH54.It has a 26mm choke, 115 main jet, 200 air corrector jet and 45 pilot jet.
Do these match a 100D2 engine?
Old 18-11-16, 05:11 PM
briwmw briwmw is offline
Here's what I wrote in my article: Racing Arnolt Bristols.
The BS1 Mk II engine in the Arnolt comes with Solex 32 BI carbs (no pumps). The first improvement was to flatten the throttle shafts to increase the area for more air flow. The car performed best with 140 main, 240 air correction and 60 idle jets. The venturis were 28 mm. One of the problems is the wear around the throttle shafts which causes poor idling but has little effect at speed. A similar carb is on the Volkswagen Beetle and that is a source for gaskets.
Note: The significant difference between the BS1 Mk II and the 100 D2 (Which I had one of) is the better crankshaft in the 100 D2.
Old 18-11-16, 08:01 PM
pasini s pasini s is offline
would you swap your 3 Webers with my 3 recently-overhauled Solex 32BI? I have them on my 403 but, being in Bologna, I'm sure that Webers will be better on my car and Solexes maybe better on yours ;-))))
Stefano
Old 18-11-16, 08:02 PM
Noot,
The carbs you are interested in buying were probably from a Bristol 405 .
LH54 means "London October 1954". The Jetting is standard 405 spec
100D2 carbs are B32 PBI-6 similar to above but have Accelerator pumps fitted .
Their Jetting standard is
Choke/Venturi 28mm
Mains 125
Air Corr 190
Pilot 55
Air Bleed 1.0
Pump 8.5
I found with the pump jets it always ran very rich during acceleration.
I blocked the pump jets and increased the mains .
After a few sessions with a mobile gas analyser and some trial and error the mixtures were very good through the range .Touring at 70mph it would achieve up to 28.5 mpg and that's fitted in a relatively heavy 400.
Old 09-03-18, 10:50 AM
trelola1 trelola1 is offline
Hi
I saw your thread on the Solex 32 Bi carbs and wondered if I could buy them from you
thanks
Michael
Old 09-03-18, 10:42 PM
trelola1,
The Jaguar Mk1 and Mk2 2.4 litre cars have two Solex B32 PBI-5 fitted.
These are basically the same as the D2 B32 PBI-6 , except the accelerator pumps squirt directly down the throat through a small brass tube , whereas the B32 PBI-6 just pushes more fuel through main jet system.
Externally they look the same . I probably have a set available that would need rebuilding and rejetting to D2 spec.
Over the years I have found that the accelerator pumps just make the engines run way to rich on acceleration. I usually block the pump jet and increase the main jet to compensate.
