Help! 1953 Bristol! What model Bristol is this?
Like Tree5Likes
  • 1 Post By Nick Challacombe
  • 1 Post By HughMiller
  • 1 Post By Geoff Kingston
  • 1 Post By DaleC
  • 1 Post By Michael Oram
Old 01-09-15, 12:48 PM
Default Help! 1953 Bristol! What model Bristol is this?
Hello! After some advice, I need to determine what model Bristol this vehicle is. I know it is a 1953, 2 litre model. Thank you in advance!
Old 01-09-15, 02:37 PM
geo geo is offline
Any clues such as photographs of the car, engine etc? What is the chassis and engine No. and any UK registration plate?
Old 01-09-15, 02:54 PM
CCA_EWLOE
This message has been deleted by Kevin H.
Old 01-09-15, 03:01 PM
Default What Bristol is this?
I see no photographs , although the posting says 3 may have been attached.
Old 01-09-15, 03:02 PM
CCA_EWLOE
Old 01-09-15, 03:07 PM
It looks like a 401 as it has no 403 on the sides of the bonnet openings.
Photos appeared thank you.
CCA_EWLOE likes this.
Old 01-09-15, 03:14 PM
Thank you for your swift response, a great help!
Old 01-09-15, 03:47 PM
The bonnet & boot badges are red, which suggests a 403 (401 badges, and most other Bristol models, have an amber background), although 403s usually *do* have '403' on the bonnet sides and boot. The hubcap badges should match. The grille is silver (401s were black) - though that's easily changed. I painted my 403 grill black because I thought it looked better (actually, I also took the '403' and 'GB' badges off at one stage, when I was on a minimalist kick).
If it's definitely 1953, I think that's too late for a 401, too.
If you can go and look at it, a simple discriminator is the front suspension. The 403 has a roll bar, the 401 doesn't. The 403 should also have an engine number that starts with 100, rather than 85.
Hugh Miller
Old 01-09-15, 05:31 PM
Well spotted Hugh, no signs of the holes for the 403 script on the bonnet and boot though , have checked the number on the BOC chassis list for the 401 and the 403 and it's not showing up on either though there are a small number of 401's that appear to have been registered in 1953.
Makes this all the more interesting, a lost Bristol found.
Old 01-09-15, 05:46 PM
Default 401 or 403
Can't tell precisely from your photos. My gut feeling is 401. Can't quite see the outer headlamps, or any 403 flank badges.
Old 02-09-15, 07:30 AM
This appears to be a 401/3, the last 401 produced which had anti roll bar at the front, PF770 headlights and the grille was normally the colour of the body.
This could have been changed as can the badges?
The registration is Berkshire Feb 1953, probably Reading and can be checked thro. this link
Berkshire car registration letter code RX
We have the same model 401 registered MXF 682, Feb 1952 in London.
Old 03-09-15, 02:40 PM
Would the 403 badges be stuck on or have locating pins through holes in the bonnet?
If the latter then there should be evidence of holes having been filled in or it has had an earller bonnet fitted if it is a 403
Old 03-09-15, 05:20 PM
The 403 badges are located by two pins so there woud be two sets of holes for them on the bonnet and one on the boot lid which also carried the 403 badge.
The badges in the photograph look in good condition so it may simply be a case of a later addition, I remember in the mid 80's there was a period where you could still get red badges but the earlier ones were in short supply.
I also checked a pair of grills I took off a late 401 a few years ago and they were silver like the 403's but again this could have been done when the car was restored. My 403 is fitted with the earlier style of badges front,back and on hubcaps but the later style of coachwork badge.
Old 03-09-15, 09:01 PM
It's not that difficult to open the bonnet and look at the chassis number on the LH chassis rail and ID plate on the firewall, which gives all the information needed.
Old 04-09-15, 06:03 PM
Out of interest my 403 grills were originally painted red and then over painted silver, but I don't know whether it was done by Bristol or when it was later painted silver.
Old 29-03-20, 03:05 PM
geo geo is offline
Sad news indeed. A genuinely helpful and entertaining character who had much knowledge and combined this with a very practical attitude to keeping one's Bristol on the road.
George
