workshop manual
Old 24-09-11, 07:26 PM
Default workshop manual
I am fitting a 603E engine and box to my 408 as the origonal engine is porous.
Does any-one have a manual for the Engine/gearbox for a 603 I could purchase, have copied or copy myself?
Thank you.
Old 25-09-11, 09:21 AM
You could try this Haynes
HAYNES REPAIR MANUAL DODGE PLYMOUTH CHRYSLER 1971-1989 AUTOMOTIE REPAIR 30050 | eBay
Why a 603 motor ? will you be able to keep the push button gear change ?
One of my favourite features !
Old 25-09-11, 09:24 AM
Or this does as well
http://www.ebay.co.uk/itm/Haynes-Chr...item483d2deb48
Old 25-09-11, 10:17 AM
Is the 408's 488 cast iron gearbox the same length as the 727 ? if not, could be a pain in the arse ! new prop etc
I don't see the advantage over a rebuild unless you got it for a bargain price -- I guess you can rebuild the original at leisure.
Sorry for being so nosey :-)
Old 25-09-11, 11:33 AM
I do. It's much easier to get get spares for the LA series than it is for the old A series. Also the LA engine is eminently tunable compared to the old A series and there is a plethora of after market performance parts available for the LA.
Old 25-09-11, 07:00 PM
geo geo is offline
Like Greg, I also thought that this was one of the most endearing features of the old iron-box. Perhaps it would be possible to use the extra lever that was added below the push-buttons on the 409 to activate the transmission brake?
George
Old 25-09-11, 07:09 PM
Banned
Default The old, pushbutton drive selector
That system was cable operated, and requires that transmission to work. Later cars went to a more conventional shift lever, so if you wish to keep the pushbuttons, you will need to keep that transmission and have it rebuilt. The internals are garden variety(cheap),and the transmission can be built to shift smoothly or harsh for longer life. Slippage is bad on anything. Good luck.
Old 25-09-11, 08:24 PM
Then you don't understand the charm of the 407 / 408. It certainly doesn't need tuning ! In fact Alan Blackwood owned my 408 back in the 60's and moved it on from fear of the speed and the law !! Alan is a fast driver and has been involved in motor sport / rally driving for a large part of his life.
The engine and gear box kits are readily available and I don't think people would be so keen on the idea if it was a Bentley or an Aston ! There are a lot less 408's runing than either of those marques.
We can all do what we want to our own cars. I guess it depends on the motivation and the circumstances and if there is anyway back for the next owner.
If you want a tuned 406 , get a 407 , If you want a tuned 408 , get a 411 S1
I guess there is a very blurred fine line between sensible upgrades and .........
I love the buttons :-)
Old 25-09-11, 08:58 PM
Default reasons
As I stated the block is porous at No7 cylinder.
To resolve that is not such a simple, or cheap task! Added to this is that my cast Iron box is leaking and will also need to be rebuilt.
As newer 318 engines are not compatible with the older cast iron box, things just compound themselves. I have a Chilterns' manual for the engine/ box, but there are nuances when installed in a Bristol, this is why I asked for a copy or loan of a Bristol manual.
I don't intend disposing of the origonal engine box, but will investigate rebuilding them.
I agree that the push button change is great, I will look at retaining, but have my doubts initially.
Old 25-09-11, 09:05 PM
I think I remember seeing something on the Imperial owners website about making newer boxes work with the push buttons and fairly sure ACCS have some experience.
I will let you know if I find the relevent info
My comments are certainly not meant as a critisism. Hope it all goes well.
Old 25-09-11, 09:07 PM
Somewhere in this load of info ! Hope it helps
Transmission and Clutch Repair Information for Imperials and Chrysler Imperials
Old 25-09-11, 09:50 PM
Transmission Interchange On Chrysler Imperials
found the place to start -- it can be done if wanted
Old 25-09-11, 10:39 PM
Phew , found a conversion supply company to keep the buttons
Imperial Services - '60-'76 A-Body Parts
Old 26-09-11, 07:53 PM
No offence taken, ordered the engine mounting brackets today from Brian M.
Thanks for the website.
On looking at the conversion kit, the key seems to be the length of the bracket attached to the gearbox, to match the travel with the dedent positions.
I'll look at the gearbox and see what I can work out.
I agree that the push buttons are nice and neat compared with that hulking great lever
Old 30-09-11, 07:34 PM
Tank you for all your comments, however, I still can't find a manual!
Can no-one help?
Old 30-09-11, 08:13 PM
Banned
Default Finding a shop manual
David, a shop manual shows scarce little about the car and its workings, as it is intended for the informed and experienced mechanic to point out certain aspects that are different from other makes. The Bristol is a combination of a number of different cars, like the Chrysler sourced engine and transmission and other operating pieces from other British and even other country manufacturers.
There is nothing unique about the cars. The hand built body being the exception. Now, if you just want a manual to read at your leisure to better inform yourself of the car, then by all means buy one. My shelves are full of manuals for many makes. I seldom ever go to them as reference.
Old 01-10-11, 12:22 AM
David,
As far as I am aware Bristol stopped producing workshop manuals long before the 603. I don't know what the last workshop manual was, maybe for the 408? You certainly can't get one for the 411, in fact you can't even get a parts list for the 411, or probably any Bristol later than that.
This was probably a Tony Crook "initiative" to protect BCLs service business.
So the best you will get is a workshop manual for another car which used the LA series Chrysler small block and the same transmission. That should be very easy to find.
Old 01-10-11, 12:57 AM
I don't know what manuals you have Ronald, but maybe you are confusing "owners" manuals with "workshop" manuals.
I have original workshop manuals from Jaguar, Aston Martin, Triumph and MG, among others, and they contain considerable detail about the car, including detailed instructions on servicing, dis-assembly/assembly, adjustment and repair of all major components of the power train. This includes diagrams, measurements and tolerances pertaining to clearances, torque settings, pressures, back lash, run out, pre load, end float, temperature, timing, sizes, fixing types and specification and special tools required.
Some are more detailed than others, but they are all very useful to both novices and engineers like David.
Old 01-10-11, 07:52 AM
I have the Technical Service Data manual for the Bristol 603 S2 / 412 for 1981 - published by the Palgrave Publishing Co LTD in 1981
This contains a lot of the info that Kevin mentions : I will try attach a photo, or you could borrow it, if you think it will be of use.
Can't upload so have sent to Kevin !
Old 01-10-11, 11:52 AM
Default 603 technical specs
Thanks for that Greg.
Unfortunately I have to impose some limits on publicly accessible file sizes that can be uploaded to the server, and at 14.4Mb your image was way over that limit. That's why you couldn't upload it
I have managed to reduce the file size and it is still readable. It's available in the Resources section here Resources - 603 (E & S) - Bristol Cars - Owners and Enthusiasts Forum
