Avon Safety Wheels
They work.Yesterday on way to London suffered a flat. As I was following an
AM Vantage at only slightly below three figures, this could have been a problem. As it was, the only clue to the situation was a sudden nasty noise from the ns rear. No yawing about or anything like that. Two morals though: first, check the pressure in the spare more often. 12 psi was a bit inadequate. Second, don`t put off taking nuts for the spare as well as for the Avons. You see, my spare is a steel wheel cos the big Avons with 225 section don`t fit in the compartment. Avon nuts don`t fit the steel properly. And, of course, the standard wheel brace fits the steels but not the Avons. Fortuneately I`d some tools in the boot. So I limped home. Peter PS I was reminded of how fine it would be to have some nice new ss nuts ... |
Peter, I think my Avons safety wheels have 215 tyres on them but the spare will fit in the wing bay - you just need to remove one or two black painted wood blocks which provided a limit/rest for the narrower steel wheel.
Now you just have to find a tyre fitter who can follow the instructions on how to remove and fit tyres on those wheels! http://www.bristolcars.info/forums/showthread.php?t=41 |
Avons
Mine are 225 section. The spare is a steel wheeled 215.
Avon Safety Wheels
Kevin,
Not sure if internal dimensions of Peter's 412 (Fridge) bay will be the same as say a 411. I am putting either 205/215 on my 406 using 15" Minilites. Wodden blocks to be removed. Clyde |
Bristol didn't like changing things unless it was absolutely essential, I'm sure that's why they survived so long. Kevin |
| All times are GMT. The time now is 05:08 PM. |
