Intermittent wipe
Anyone retro-fitted an intermittent wipe on their 411? I think it would be a very useful upgrade if I am going to use the car regularly...which I am.
Also, my wipers wont park so I have to switch them off EXACTLY at the right time. I guess this is a wiring issue...anyone got a photo of theirs correctly wired up? Must have got them mixed up when doing the woodwork. Hopefully. |
Intermittent Wipe
Hi
My 411 has only ever been serviced by Bristol and (until a recent re-fit ) I too had to switch off the wiper blades at precisely the moment they hit the rest position - a great game to pass away idle motorway time ( if your motor is like mine you may also be treated to a random "intermittent" wipe as well ! ) I can not give you any techical reasons but did not want you to assume that it was a result of any faulty re-wiring on your part. Good luck |
Intermittent wipe
The wipers on my 603 will occasionally self park, I believe the wiring is correct and can only assume that the microswitch on the wiper motor is intermittently faulty. Not east to get at, its next to the glove box.
I had an intermittent wiper switch fitted to my 412 by BCL, it is a big improvement however they don't park in the way they do with the original switch. I guess BBR will be able to fit something similar if you are near Bristol
Now fixed - I had two wires transposed in the switch. I have posted on my website a diagram of the correct wiring. Wipers now park correctly. Hurrah!
See Home - The Bristol 411 for more info. Latest News November section |
I had look at your website - useful diagram
You mention about the engine running so hot it will crack the cast iron heads running on LPG and swapping them for ali -- if it's hot enough to crack steel it will warp aluminium.! Never heard of anyone else having a problem with a cracked head using LPG. Why do you think this will happen ? |
Info on heads came from ACCC when I bought the secondhand tanks...something to do with the cooling on the old heads? TBH, I might just run it anyway on LPG and just change the head if/when it does go.
| All times are GMT. The time now is 09:30 AM. |
