407 front calipers
me again, still trying to get my car MOT'd.
Problem now with front disc brakes, which I think are Dunlops, piston jammed on and other leaking badly. Are there any spares for these brakes OR should I replace the entire calipers with something with a bit more meat?? |
407 Brake Calipers etc
As they say, further to other replies, everything for the Dunlop Brakes are easily and readily available.
Past Parts of Bury St Edmunds, not only supply the parts from stock but will re-sleeve brake cylinders. The brakes were used in Jaguar E types etc from 1961 to 1963 for instance. Do not be tempted to change to cooper kraft as the dunlop's give readings at MOT time better than many modern cars. I have had my 407 since 1999 so have had to source lots of parts. Any help willingly given. Do not forget to try Brian Marelli as Bristol Cars Service. Past Parts Ltd, Unit 4 Chase Road, Northern Way Industrial Estate, Burt St Edmunds Suffolk IP32 6NT Tel 01284 750729 Fax 01284 756240 pastparts.com: The Leading Past Part Site on the Net email: [email protected] Nick 407 6028 |
Tks Nick, am in contact with Past Parts & will not be pursuaded to dump my Dunlops.
Where would we be without the computeer??? David |
| All times are GMT. The time now is 03:55 PM. |
