603S2 Distributer
i have discovered my dizzy has points with vac. advanc. I thiught these came with an electronic distributer? well that what I have read.
Obviously I want a fully electronic device so can anybody advice on the options or if they have experience regarding this? |
A distributor, or Electronic Ingnition Upgrade
I am not familiar with the model you have, but if it's drivetrain is either a small block or big block Chrysler product, it is a simple matter to use your same distributor and install a Pertronix ingnition. This small device fits inside your stock distributor and converts it to Electronic. It will also use a coil (they have an excellent one) or your stock one. Their coil will handle a full 12 volt charge, giving much hotter spark, whereas your stock coil must run at a lower voltage to prevent it from overheating, but you can use the stock coil on this system, and keep your voltage dropping resistor in line.
Distributor
Ronald
Thanks for the advice I will look into the sugested system |
| All times are GMT. The time now is 12:59 PM. |
