403 dashboard lights
I started my 403 up and the fan was blowing so I turned it off and appear to have fused something as dash board the lights do not work and the fan has stopped.
Everything else still works & I checked the two fuses under the controller. Is there another fuse hidden inside? Peter |
Where is your electric fan switch connected? The fans draw quite a bit of power.
Dave Dale. |
Thankyou Dave,
I'll check it next time I go to the car. Is it a push/ pull switch as well? (or just the button pulls on the stalk). Regards, Peter > |
Generally the dashboard knobs with the knurled perimeters ( the 'L' knob should be knurled ) operate rheostats only and rotate only. Another example is the demister knob. The knobs with the smooth perimeters are push / pull for on / off operation. BTW, I have converted my demister switch to operate the fan at maximum speed as an on /off switch but keeping the original knob. Hope this helps. Dave Dale. |
| All times are GMT. The time now is 09:06 PM. |
