Bristol 403 parts suplyer
Dear all,
Having recently purchased ex Stephen De'Ath's green Bristol 403 UPL566, although the car is in a very good overall condition, I still am in need of some parts. So, I'm trying to locate supplyers on the following items: Door rubber seals Lucas PF770 headlamps complete with backshells Triple Solex carbs repair kit: gaskets, etc. Steering wheel refurbishers. Any clues?, Yours for longer engine roars Joseph Portugal |
Try item number 120324097222 in ebay for the carb kit -- not sure if it's right for your car.
Hope this helps Greg |
Door seals - if Bristol Cars don't have them try Baines or Seals +Direct. You might find something similar with them. Lucas PF770 headlamps - try Holdens Solex carb repair kit - Carburettor Exchange. I got mine from them. Steering Wheel Refurbishers - Myrtle Productions. They advertised recently on e-bay a restoration of the Bristol Bluemels wheel for 325GBP. Also there is much useful information and sources for parts on the BOC Knowledge Base but you have to be a BOC member to use it. Good luck, Richard |
Dear Richard,
Many thanks in advance. As you said, in fact I am a BOC clubmember, having recently joined the Club in late 2009. I'll try the contacts you mentioned, and I'll keep you informed. Yours for longer engine roars, Joseph Portugal |
| All times are GMT. The time now is 11:45 PM. |
