Lucas Windtone
An odd but simple question. Where are the horns located on a 400? Mine appear to be missing........
Lucas Windtone
Clifford ,
they are attached to a angle iron bracket which is bolted to the steering rack securing bolts . I can send you a photo if required , Regards Geoff |
Lucas Windtone
On mIne they are in the center in front of the main spring. Basically some
8" behind the front number plate. Others may vary and in some 60 + years.... Dorien |
Lucas Windtone
Dorien ,
yes you are correct but check where& what they are attached to !!!!!!!! Geoff |
Thanks for that. Sure enough I have a bracket with holes in it...
| All times are GMT. The time now is 09:04 AM. |
