-   -   Oil filter adaptor (https://www.bristolcars.info/forums/showthread.php?t=423)
Des 01-04-10 08:07 AM
Oil filter adaptor
Just in case anyone else has been contemplating washing their old Vokes filters, I've run quite low on them, came across a company called Flexolite offering an adaptor to take readily available cannister types, about £50 inc p+p, but looks nicely made, instructions included, delivered very promptly and included a filter, a decent Mann one at that, good value I think.
Bellerophon 01-04-10 08:30 AM
Oil filter adaptor
WARNING, make certain that the replacement conversion unit is compatible
with the Bristol system, (from the centre out) as most cartridge types work
with the oil flow in the opposite direction and if fitted could result with
paper parts blocking the oil ways.
My regards,
Bellerophon
Des 01-04-10 04:28 PM
Good point Beller, I remember suspecting the Bristol filter works inside out, in that any crud stays within the filter rather than settle at the bottom of the bowl. Now I'm home I've taken a better look at the item, and it's not so much an adaptor as a replacement for the filter housing, which will have the filter will screw on horizontally. Only snag here is not being able to completely fill a replacement filter with oil before fitting, not really a problem, although I'd best ensure filters have a non drainback valve.
dkleeman 28-04-10 03:24 PM
Is it possible to buy replacement cartridges for the original filter, or is this just a pipe dream?
Daniel
Geoff Dowdle 28-04-10 07:48 PM
Oil filter adaptor
Daniel ,
I have a limited quantity of replacement Bristol 6 cylinder Vokes oil filter
elements suitable for types 401 - 406 plus AC , Frazer Nash etc (but they
are not suitable for the original 400 Tecalamit type )
If you are interested contact me off Forum at [email protected]
kfitzgerald 28-04-10 07:58 PM
Oil filter adaptor
In the states you can find cartridges at NAPA auto stores. Kevin
dkleeman 05-05-10 04:02 PM
Would anyone be kind enough to examine the attached photos of my filter and housing and hazard a guess as to what make it is? It is from a 401 (1951).
There are no visible marking or brand names. The length of the cartridge is 5 3/8 in and the diameter is 2 3/4 in.
Daniel
cornelius 05-05-10 05:58 PM
Oil filter adaptor
Hello,I think it is a Purolator, check the at www.MGAguru.com it is a very good artticle
The thick ring at the bottom of the cannister proves it is a purolator one
Cornelius
Geoff Dowdle 05-05-10 07:50 PM
Oil filter adaptor
Daniel ,
This Oil filter assembly is not the original Vokes type fitted to 401 - 406
, or the earlier Tecalamit type fitted to 400's
If you need a replacement cartridge I suggest you simply take the old one
to a spare parts supplier and match one to fit.
But if you want your 401 to be to original specification
I have a spare original Vokes type with new cartridges to match
OR
I can supply a adapter to suit modern spin on filters
dkleeman 06-05-10 01:05 PM
Thank you both for very helpful answers.
Daniel
dkleeman 05-09-10 07:59 PM
I bought an adaptor kit FA021 from Flexolite in Salisbury, UK for about £40. It has worked out very well.
Daniel
Bellerophon 06-09-10 04:50 AM
Oil filter adaptor
Daniel, with regard to your oil filter adaptor, I take it that it enables
you to use a current screw on canister filter. On the Bristol engine the oil
flows through the filter in the opposite direction to the canister types,
so check that your adaptor does reverse this or you will risk the
possibility of parts of the filter blocking your oil ways.
Also it is good that you have found some one to re-spray your car, but you
have most likely found out that the body frame is welded to the chassis and
difficult to remove. However, if any of the original paint or filler
remain on the car it should be removed and new applied as the old looses its f
lex ability with age and will craze with the expansion of the aluminium.
I wish you luck with the re-spray.
My regards,
Bellerophon
dkleeman 19-10-10 09:40 PM
Thank you very much for the advice Bellerophon.
The respray is being carried out by G & B Autospray in Royston, Herts and is well under way now. It is indeed a full bare metal respray and their process seems surprisingly similar to the methods described in the 401 launch press release available at the JEL450 web site.
I have been able to visit several times during the preparation and so far, I would heartily recommend them. The big question now is what colour to paint it. For the last 20 years I have known it as a cream coloured car, but it turns out that it should be Cambridge Grey (green really).
Daniel
Rubbond 20-10-10 08:00 AM
Oil filter adaptor
I still regret not painting my TR4 in the factory baby blue racing colour
when I had the chance, instead sticking to the bright red in which it left
the factory.
My advice would be not to paint your car in its original colour if you don't
like it!
