Fuel Pump in earlier V8s
Can anybody tell me where the fuel pump is located on a (V8 (410 in particular)? I suspect that the car has picked up some rubbish into the fuel system and sustained running at higher speeds has the engine misfiring and showing signs of fuel starvation. I want to check the fuel pump and replace the filter. Thanks, John Keighley
Hello John, my fuel (in a 408) pump is in the right front wing near the battery - I guess this is the normal position in a V8 Bristol. Best Hans
Hi John,
Unless your car has been altered to an electric fuel pump, many have. The mechanical fuel pump is located on the LH side of the engine block, looking from the front. It is a Carter M2504 S on my 407 Hand book say no maintenance is normally required ( it is mechanical). The pump can be removed from the engine and dismantled and cleaned the following parts will need to be renewed at re-assembly, M.203-89S Diaphragm Assembly M.203-46 Outlet Airdome Diaphragm M.121-124 Flange gasket. The Fuel filter. Moper 2084 258 should be changed every 10,000 miles. Hope this helps, I have converted my 407 to an electric fuel pump located under the offside wing on the wheel arch. The filter is an in line particulate transparent filter located under the bonnet between the new fuel pump and the carburettor. Nick Challacombe |
My 410 has an SU electric pump, located high up in the boot on the right hand side. I think some other cars also have had them fitted in the boot. The diaphragms (it's a double pump) do not last forever and I had to rebuild mine a few years ago after it failed without warning on the motorway. If it's not original, I would guess it was fitted when the car was restored circa 1990.
John
My fuel pump in my 410 is in the boot as described in Sam's reply. On my 411 which was a mechanical pump but not working properly due to slight wear on the rod and cam we conveted to an electrical pump. The first attempt with a Holly pump was a disaster, mounted on the boot bulkhead it made more noise than the engine on tick over and low speeds, this was replaced with a Facet pump also bulkhead mounted and much better, just the priming sound before start up. I am told this pump would also work mounted up front near the battery but have not tried that so can't be sure.On my 410 I had the pump rebuilt with an electronic update to do away with the points and I must say it works very well. Geoff |
Thank you all for replying, I should have known where to look but as the car was going in to my local mechanic,didn't have time to search. It is on the right hand side of the boot floor. As it happened, the pump turned out not to be the culprit but we discovered this afternoon, the filter was almost fully blocked due to having sat around for an extended period of time. At this point, a new filter has restored normal operation. Since emerging from restoration the car has covered about 3500Ml, so I'll have to keep a lookout for crud in the fuel system.
John Keighley. |
reading this thread made me wonder if I knew anything about the fuel pump installed on my 409, and the answer was negative. I was quite sure that I didn't see any mechanical pump in the engine bay so I asked to the guys at the body shop (where my 409 sits now for some minor work) to check into the boot. In fact the pump is there, exactly as described by Sam on his 410, and looks like a double pump. This is a picture of my pump: http://www.stefanopasini.it/Bristol_...uel_Pump_1.htm I cannot see any numbers on it because it is installed in a position where is not very easy to check; I would like to ask if anybody has any idea of what model this pump might be and what could be the correct replacement for this pump. Maybe an 'electronic' pump might be better? I have checked Burlen site: http://www.sucarb.co.uk/ProductCateg...px?ParentId=16 to find several types of double pumps, but I couldn't decide what would the right choice be for my 409. high or low pressure? Points or electronic? Thanks, as usual, for your help, Stefano |
Mine was a double pump like yours, part number AUF406, equivalent to the AZX1404, which is in turn identical apart from the fittings it is supplied with to the AZX1405, sold by Burlen. I would presume that the AZX1405EN is simply an electronic version of the same pump. I'm no expert, but I suspect an electronic pump would give similar advantages and drawbacks to electronic over points ignition
This is what I put on the BOC Wiki about it at the time (July 2007): "The fuel pump on my 410 recently gave up the ghost, and so I was obliged to investigate current replacement options. Burlen Fuel Systems were very helpful; my car had an SU twin pump, model AUF406, fitted as described above, in the boot. The AUF406 is now known as an AZX1404. The AZX1405 is apparently the same but comes with different fittings for the fuel lines, although if you are replacing a pump you would already have the correct fittings so it should be trivial to swap them over. Burlens offer a restoration service, but that (at time of writing) has an 8-week turn around, and costs only a few pounds less than buying a new pump. However, they also sell overhaul kits, which contain new diaphragms, gaskets, points, and all the consumables apart from the main coil. These were fairly straighforward to fit, and have the part number EPK300. You need two kits for the twin pump obviously. Mine initially still didn't work, but once I'd taken it apart, checked all the setup, and put it back together a second time it seemed fine. If the coil itself has failed (which according to Burlens is extremely unusual) the unit will need complete restoration or replacement and the overhaul kits will be of no use." |
Hello Sam,
thank you for your message. My pump looks very similar to the AUF406/AZX1404 that you mention, so I think that I could just order one and be safe with that. I'm wondering if it is better to buy the electronic version AZX1405EN or the classic 'points' type, though. Maybe some of you with a real understanding of these pumps has a definite opinion on the possible choice? It would be a great help. Thanks Stefano |
I can understand having standard service items as spares,although none are rare on a V8, but I do not understand the logic of keeping items like fuel pumps.
However, what do I know ! |
I decided to stop worrying about my old fuel pump, that works fine but looks quite 'tired', so to speak, and I asked Burlen what pump would they recommend. They said that AZX1405EN is the right electronic pump to substitute my doubloe SU. I bought one and when it arrives I shall install it, keeping the old one as spare. I'll let you know what happens when I have installed the new one. Thanks Stefano |
Mechanical Pump
1843400 Fuel Pump up to Chassis No. 7350 and 909-1-33012 Fuel Pump Chassis No. 7351 on & 410 George |
I didn't realise that the fitting of electric fuel pumps to V8 Bristols was so common. I suppose I shouldn't be so surprised given that you can buy a Mopar branded blanking plate for the spot where the mechanical pump goes (for B/RB engines at least). That suggests it is very common practice. It certainly makes starting the 400 CID engines much easier from cold.
I don't think it really matters what pump you have so long as it can supply an adequate flow rate and the pressure isn't too high. You wouldn't want any more than 5 psi, but you can use a fuel pressure regulator if necessary, I have one on my 411. |
1969 383 - 411 (S1)
Some years ago I fitted the Edelbrock carburettor, fuel pump (model 1723) and inline filter. All work like a dream. From the Edelbrock item description: "Performer RPM Street Fuel Pumps Designed for use with all Edelbrock carburettors used in Performer or Performer RPM applications. The unique valve design improves flow quantity and quality, and will support engines up to 600 hp. High-volume, 3/8" NPT inlet and outlet surpasses the capacity of conventional models. Produces 6 psi and does not require a regulator. For gasoline only. Clockable lower housing can be rotated for best inlet/outlet alignment." JEVS |
George |
> Hi Sam,
> just a question: did you have to fit a fuel pressure regulator after the 1404/1405 pump? If you did install one, what did you use? Thank you! Stefano > > > > > > |
The SU pump was already fitted when I bought the car. I don't think there is a regulator fitted, but I am not certain what it would look like or be located so if anyone can tell me I shall check.
Geo
Thanks for your contribution, but I am not sure what you are trying to say! Some twenty years ago I started to 'update' my 383 engine (from 12 miles per gallon). I replaced a lot of items and today I am getting 20 (+ or - 2) miles per gallon depending on the traffic and my temperment. Remember - the Canadian '383' was manufactured for use in California which then had very tight emission controls + lead free fuel. This engine was fitted with a Carter Four Barrel carburettor which met those emission controls by restricting the airflow through it. The Four Barrel Weber carburettor allows some 40% more air (cubic feet per minute). I have a 360 degree unrestricted air filter + new intake manifold fitted. No modification to the bonnet is/was required. The Edelbrock fuel pump was only part of that updating process. I have three 1950's Carter mechanical fuel pumps which broke down - the Edelbrock pump uses a different method of pumping and is self regulated at 6 psi as required by the Weber and is much quieter. Some years ago, the 'leaded' fuel disappeared from the market. To date, I have not re-tuned for that loss. My email is jevs@iol.ie if you would like more detailed info. JEVS |
My 313 Canadian Plymouth/Dodge engine had no emission controls and was
designed to run on leaded fuel. It has always had a Carter 4 barrel carburettor and a large circular air intake to the carburettor. No modification has been made to the fuel side of the engine at all apart from changing, for convenience, from the std Carter mechanical fuel pump, to a Facet electric fuel pump situated by the servo under the offside front wing. The Facet comes with an adjustable regulator attached. I also put in a dual point distributor and an inline fuel filter. I have now done 30,000 miles with this set up in the last 11 years with 19mpg on runs, no sign of any valve seat wear, the older the engine gets the better it gets. The 407 was renowned for overheating but since I rebuilt the radiator 10 years ago and kept the right amount of anti-freeze in summer and winter, no problems. Keep it simple I think is the answer. Nick |
| All times are GMT. The time now is 01:07 AM. |
