-   -   402 drophead...doorlocks.. (https://www.bristolcars.info/forums/showthread.php?t=350)
Griebel 25-01-10 05:04 PM
Hallo Sir's...
I'm totally new in this Bristol game, so please be gentle
We are in the process of a complete 402 restore, and right now we are looking for some info/pictures of the door-lock mecanism...there are supposed to be some kind of rubber device and an aluminium ring attatched to the double doorskins ? I can see the sorry remains of the rubber,but I am not shure how this is supposed to look...(both inside and outside the door)
Can anybody help me please ?
Hope that you can understand my english !
Best Regards from,
Griebel,Denmark
Des 25-01-10 08:20 PM
I have my 403 doors apart / locks out, at the moment, so will take
pictures and post here, there is indeed a rubber diaphragm held into the doorskin
with a very big circlip. Do be careful with the lock barrel, if it comes
apart it's quite a fiddle to get back together.
Griebel 28-01-10 03:59 PM
Thank you very much !!
Des 05-02-10 11:54 PM
I had a fleeting visit to the workshop today, managed a few quick pics, the rubber diaphragm in situ has deteriorated / shrunk, and is not secured around its periphery, and is obscuring the bottom half of the big rusty retaining circlip, which should be in front. The lock assembly sitting on a paint can has a rubber which I made for it, it's a pleat cut from an Austin Mini driveshaft boot, a circle of stiff wire popped inside to give the periphery enough meat to be retained in its housing. If you go this route do select a boot made from a soft rubber otherwise the lock button return springs may struggle with their task.
Since making mine I found a pair of unused rubbers mounted elsewhere on the car, that's Bristols for you.
Griebel 06-02-10 01:04 AM
Thank you for the pictures ! I'll try to find some suitable rubber...
Des 26-02-10 09:57 PM
I came upon my doorlock rubbers today, these are original ones, the pics may help with sourcing / manufacturing your own.
Max Tone 26-02-10 11:50 PM
The concentric mouldings between ID & OD may be original, but just as
likely/easy to be formed by shape of relative components in situ under
compression.
I'd suggest going to local tyre shop & begging scrap inner-tube of approx
right thickness, then cut to size! A kitchen apple-corer might provide
internal hole dia. used as stamp, whilst pastry-cutter might do OD.
Rob
GREG 27-02-10 11:40 PM
Or make new ones.
Hard Rubber Moulding Kit (500g)�.(R101) - Miscellaneous - Frost Auto Restoration Techniques
Greg
Griebel 28-02-10 01:58 PM
Thanks to all of you for pictures and advise ! Very much appriciated :)
Griebel
GREG 01-03-10 10:18 AM
I was just talking to Brian May and he has stock of these rubbers. Sorry but I always assume that people talk to Bristol Cars, ACCS and Brian May first.
Brian May
497 Petersbrook Road
Shirley
West Midlands
B90 1HZ
Telephone 0121 430 3767
E-mail [email protected]
Hope this is not too late
Greg
