-   -   410 Temperature gauge (https://www.bristolcars.info/forums/showthread.php?t=2496)
OakHouse411 09-11-26 12:41 PM
Help! My water temperature gauge has stopped working. What thread is the fixing nut union please?
David C 11-11-26 06:27 PM
From memory, the thread on the nut for the bulb is 3/8" BSP. The thread in the manifold is either 5/8" UNF or 1/4" NPT. They have the same diameter and pitch but NPT is tapered. A straight union should screw far enough in to a tapered hole on the manifold for a decent hold but will need a bit more thread sealant.
OakHouse411 11-11-26 08:27 PM
410 Temperature Gauge
Thank you David for the info
