-   -   Bristol Dx6a and DXH6a differences (https://www.bristolcars.info/forums/showthread.php?t=2467)
flyinghorse1 08-05-26 05:40 AM
Does anyone know the key differences between these two distributors.
I know the DX6a is for a 400, but Bristol used the DXH6a on the later 100 series engines.
It’s the advance curve similarities I’m actually interested in as I’m working on a 100 d series engine that for some reason has the DX6A fitted.
Graham
Geoff Dowdle 08-05-26 06:41 AM
Graham,
The only difference is that the DXH6a has horizontal outlets in the cap for the spark plug leads , compared to vertical in the DX6a .
Both are very basic distributors . My experience over 50 plus years that even a new Lucas distributor is only good to about 3500- 4000 rpm , much over that they become erratic , probably due to points bounce .
I would not consider the original ignition advance curve ,as today's fuels, higher compressions of most Bristol engines today, often different valve timing etc etc , the large total advance of the 50's is not needed today.
I do not and will not run a Lucas distributor in either of my Bristols , especially if it was a D2 engine
What D2 engine are you working on ??
I have new horizontal outlet distributor caps if you need one .
Sydney/Australia
JoeF 08-05-26 06:53 AM
The key difference is the cap. The "H" denotes horizontal ( side entry ) exit holes for the HT leads. DXH6A was used for Bristol-engined AC Ace and Acecas. The cap part number is 407279. The DXH6A distributor part number for the AC cars is 40551 , which will be on the distributor body, as should be "WG-16". The part numbers determine the advance - in this case it is ECM curve 641 using spring set 424216. This is different from the other 2 litre distributors, but I don't know the actual curve, sorry. The Distributor Doctor should be able to supply the springs if you need new ones.
flyinghorse1 11-05-26 09:01 PM
Thanks for the clarification of the model differences.
Oddly my Dx6A has a horizontal exit cap which seems to work fine.
I guess the cap fit both types.
The conclusion for me Is that the Lucas original advance curves can be improved on by using a programmable advance curve and testing on open road / rolling road to get the best out of the engine given modern fuels, higher compression and vernier valve timing settings.
Graham
