-   -   Heater core Bristol 411 S5 (and others) (https://www.bristolcars.info/forums/showthread.php?t=2447)
Thomas591 26-01-26 07:30 PM
I am looking for a new heater core/matrix for my 411 S5. Coleman classic cars have commissioned them, but the price is on the high side (just my personal impression). Does someone know if the matrix is shared with other British cars?
Thomas
Kevin H 27-01-26 05:18 AM
Hi Thomas,
Are you looking for the matrix core itself, or the whole heater box with flaps and control levers?
It is possible (maybe likely) that the matrix core itself is common to other heater boxes, but not the box itself. I note that in the heater repair document authored by David Billington he says:
"to repair the box, I purchased a similar second-hand heater from a BMC specialist for £29. I cut away the rotted sections and had sections from the donor heater box welded in their place, then I exchanged the relevant linkages"
As an alternative, you could consider replacing the heater box with an air conditioning unit which provides heating and cooling?
Thomas591 27-01-26 07:36 AM
Hi Kevin,
I overhauled my heather box with new seals etc, but still the output is meager.
Therefore I am only looking for the matrix core.
My idea of a “BMC-Standard” core comes from the Daving Billington article.
My car came originally from the factory with a AC fitted, which I would like to keep, as it still works well.
Thomas
AndrewA 05-02-26 05:51 AM
Hi Thomas
On my 410 I sent the matrix away to these guys who were recommended by someone on here.. https://www.aaronradiator.co.uk/classic-heaters/ who did a good job. Once engine warmed up, output is certainly sufficient for me! Miles better than before it was done.
Cheers
Andrew
Thomas591 16-03-26 05:18 PM
Hi,
I found out that https://thecarheatershop.co.uk can supply a heater matrix for the 412.
Do the 411 and 412 share the same heater unit?
Please advise.
Thomas
Thomas591 24-05-26 03:22 PM
For the archives:
I can confirm that the heater matrix for the 411S5 and 412 is shared with the
Triumph 2000, 2500 and Rover P4 and P5.
I bought a new one from https://thecarheatershop.co.uk/ for 150£ plus postage
