406 indicator relay
Hi there
Can anyone point me in the direction of where this is situated in the dash? I have an issue where the left hand indicators are not working - no clicking from the relay. Right hand ones operate as normal. |
Usually the relay is in the feed to the switch which then goes left or right, so this would point to switch fault, wiring or both bulbs blown, is there a hazard switch? These add to the fun.
If I remember rightly the 406 has two indicator relays mounted above the battery under the driver's wing. One for left, the other for right.
No pump - they are vacuum operated!
Hi thanks for this - I should have known they would be in the RH wing. Yes, there seems to be two - one for the left doesn't click. I will start here and then check switch
Just the one, sadly, and that failed on me recently. I had someone tailgating me, seemingly desperate to get by. I suddenly had to brake and he very nearly had a look inside the boot. I wondered why he backed off so far until I realised the switch had given up.
| All times are GMT. The time now is 11:30 AM. |
