Window Weather Strip (Drivers and Passengers windows)
Hi
Can anyone advise on where to obtain the correct rubber weather strip that is found next to chrome and glass on a 603. Or any V8 Bristol? The current "worn" rubber slides along a narrow channel located in the chrome fitting. Thanks in advance. Mike Murray |
It is very likely that Graeme Payne at https://www.classicbristolcarpartscompany.co.uk/ will have exactly what you are after and may indeed be able to suggest an upgrade
If that fails https://coh-baines.co.uk/ offer an astonishing array of rubber sections |
| All times are GMT. The time now is 02:42 AM. |
